DHP482 Notes / observations
SneakyMember since Dec 2020
Hi,
Late November I purchased the DLX2131SY Kit, and noticed the following with the Drill:
– Noticeable axial play within the shaft / gearbox – this makes neat drilling somewhat challenging; The chuck runs true however.
– Rattling noise when spindle is slowing down / braking – only in Hi gear
– Gets quite warm under load (normal for a brushed unit I guess?)
(My AEG BSB 18ST doesn’t have these “features”, or they’re nowhere near as pronounced – even nearing its retirement!)
Took the DHP482 back to the retailer – they idled and smelt it (?), said it’s “normal”. Raised it with Makita – said to take it to their repair centre.
Just want to figure out if I got a lemon or if the above is acceptable?
Cheers 🙂
aessuMember since Aug 2017
The gearbox/clutch is broken. My DDF482 (wich is the same drill without hammer function) had the same problems. I had it fixed once, and when it broke down again I bought a DDF484 which has metal gears, DDF482 has plastic gears.
aessu wrote:
I opted for the DHP482 because a number of sources stated: “All metal gear construction”. Unless these vary by region / country of manufacture?
Either way, the rattle noise and other matters make me nervous. The thing is brand new.
That’s crazy it has plastic gears.  I know some drills have them but I would have never thought the DDF482 had them.
So it hasnt been used? Shouldnt do that. I broke mine twice with a step bit into some 3mm thick steel
Ferino815Member since Dec 2020
This do almost every makita drill ..my dhp458 too .
i dont know why …
btw Dhp482 in our country have steel gears
