Hello,
I have problem with DCN660 nailer, When i press trigger left light flashes 20 times. Motor doesn’t run. When i opened it and reinsert battery it runs few times if i push switch inside (one activated when gun is pushed against surface), but after few attempts (or if i put case together) same problem.
Any advice would be much appreciated.
Thanks
Do you ever find out what was wrong with it as I have the same issue?
Welcome to the forum.
What happens if the steps defined in the Instruction Manual are followed for clearing a jammed nail?
FWIW @Flyer13is is not good form to reply to a dead topic and is better form to create a new topic for the current issue.
Flyer13 wrote:
On 9/1/2021 at 12:57 AM, Flyer13 said:Do you ever find out what was wrong with it as I have the same issue?
Did you found a solution for the problem? 🙂
