XGT 150mm/180mm/230mm (6″/7″/9″) angle grinders and BL4050F battery
QuasarCZMember since Jul 2017
With these bigger grinders is XGT line becoming interesting for me. What surprises me little is that 230mm grinders have one battery only. I was expecting two battery setup. In manual there is a new BL4050F battery recommended for it. Has anyone info on this battery? Bigger 5Ah capacity is obvious, but maybe bigger cells for higher power output? What does “F” stand for?
150mm 6″ – GA033G/GA034G/GA035G/GA036G
180mm 7″ – GA037G (with AWS)
230mm 9″ – GA038G (probably with AWS)
[External image (voltechno.com), not copied]
ToolBaneMember since Jan 2018
There hasn’t been much of any noise about larger cells anywhere else, so this is probably either a matter of more cells or newer cells of the same size that just have higher capacity. But to do more cells of say the 18650s that are used in LXT batteries, you’d have to use twice as many (20 cells) to retain a 36V nominal operating voltage. I’m having a hard time seeing how they’d want to make that fit in anything that fits comfortably on their existing tools.
MartinMember since Apr 2017
BL4050F? Wow! Could that F be for Fluoride? That would explain this whole XGT-thing. Next generation battery technology. Search for Fluoride-Ion Battery, Kyoto University.
Martin wrote:
Well THAT technology could be a tantalizing prospect…although that seems a little too fast to hit the market to me
What i have found some info on net, BL4050F battery will be probably 20 mm longer and 19 mm taller than BL4040. Maybe 20cell 18650 design?
