Need Suggestions for best tool for cutting bookshelf lip to fit a bed.
king301Member since Nov 2020
Just bought a new house and the master bedroom has a bookshelf that wraps around the bed. As luck would have it our bed frame is about a 1/2″ too big. Need thoughts on best tool to trim the offending lip. Its about 1.5″ thick. Would like tool to make as clean a cut as possible. And the blade needs to be as flush as possible to get past the upright wood panel without having to angle the cut. Thanks in advance.
Not sure if that is wood or veneer.  I am guessing you are cutting that small part on the back of the shelf but not sure.  If so you can’t get in there with a circular saw.  I would use an oscillating tool.  Just score the area you want to cut with a box knife.  Then put the oscillating tool on a slow speed and go over the area you scored to make a nice trench.  Once you have a good trench and you know the tool won’t bounce around, you can increase the speed and cut through the wood.
