18v bandsaw p590 blade comes off
John RMember since Jul 2020
I have the p590 18v bandsaw and (almost) love it.
The only issue I’m having is EVERY SINGLE CUT I make, the blade binds and derails.  I’m am electrician, using it to cut emt conduit, spiral flex, pvc-coated spiral flex and threaded rod (3/8 and 1/4″).  It cuts all these things great, but boot until the second attempt.  I start the saw off the material, bring the blade into it and poof.  About 1/16″ into the material, blade binds and comes off the wheel.  Put it back on and go again, no problem.  Anyone have any ideas to resolve this?  I’m almost ready to chuck it and go buy the Milwaukee, and a set of batteries.  But I’d rather pay rent, they’re about the same.
Have you tried to adjust the tracking?  There are two set screws on either side of the tension release lever.  You just need the hex wrench.
I haven’t adjusted the tracking yet, although I did think about it.  The reason I didn’t is that it tracks fine under no load.  And after re-installing the blade for the second attempt, it cuts fine.  It just doesn’t like that fresh cut for some reason.  Quite odd.
Very odd.  I would think it has to do with something in one of the wheels.  When a load is put on, then something is moving on one of thw heels causing it to lose tracking.  I just don’t know enough about that tool.
