Archived from the Tools In Action forum (Test & Measurement). This thread is read-only.
I have a MAX power 9.6 V drill, switched on trouble, seems contact not good, some time switched on at once, some time can’t switch on, changed a new switch, not luck. what can be the reason?
Thanks
Shanren
The reason can be deeper than switch, inside of a drill. If you want to repair it for yourself, you should open it up, and look carefuuly for any visible damages. If you don’t see any I would recommend you to go to warranty service or technical center.
Brush or brushless
Can you post pics
Sent from my SM-N960U using Tapatalk
