DCD796 chuck axial play? (not wobble)
toolert2Member since Apr 2020
Hi guys,
I have a pretty new DCD796 (about 3 months old) that I absolutely love.
However, I just noticed there is considerable movement in the chuck in the axial direction (left to right in the pictures below)
When you press the chuck with your finger towards the drill, the whole chuck moves about 4mm or 1/8″  (see second photo).
The movement feels kind of springy, so I suppose it could be something to do with the hammer drill function.
I can’t remember if the drill had this from the start, but it somehow doesn’t feel right. The drill still works great.
Can somebody confirm if their own drill has this as well, or should I send it back for repair?
[External image (i.ibb.co), not copied]
framerMember since Jan 2011
its normal.
CharlieMember since Aug 2013
It’s a hammer drill which means it has to have that much movement to allow for the hammer function.
Ashley AgerMember since Apr 2025
I have just bought a DCD796 and the chuck on mine moves “in & out” when stationary and can be pushed in with a finger (see photo’s above) On reading the messages above, I assume this is normal as part of the “hammer” function. It does seem unusual from previous drills owned. It works fine!
