Greetings,
I recently bought a Ryobi 40V cordless 14″ chainsaw to do some yard cleanup, including taking apart a couple of trees that came down. I have both a 4Ah and 6Ah battery for it, and regardless of which battery I’m using the chainsaw stops and refuses to restart after a couple of minutes of use (and I do mean a couple of minutes.) Pulling and reinserting the battery will let it start up again, for another 30 seconds or so.
Ryobi support was completely unhelpful. Is this intended design, with the saw stopping because it’s getting too hot, or do I have a defective saw? Any advice would be helpful.
Thanks!
Hello fjacquette,
Yes, I experience the same problem with my saw but I have an older (2014) model. Frustrating to learn that the same problem exists in the newer saws as well.
I just watched a video breakdown of the disassemblly and troubleshooting for this particular problem and, according to this video, the problem was loose wire connections in the internal components. All this person did was disassemble the unit carefully to uncover the electrical system from the battery terminal to the motor that spins the sprocket, tighten some flat head screws, test the unit, and reassemble. This seemed to have fixed the issue according to the video. Here is the video link:
I will probably be attempting this procedure in the near future.
I would say that since you have recently purchased a newer model that it is probably under warranty and you should either return it to the store or contact Ryobi for replacement. Hope this helps!
fjacquette wrote:
On 4/3/2020 at 3:31 AM, fjacquette said:Greetings,
Thanks!
In my opinion battery and electric chainsaws do not work well like gas chainsaws. I didn’t work before on these chainsaws. But I really want to test a battery or electric chainsaw.
I have the same problem, sometimes the saw runs well until the battery runs down, sometimes the saw will just quit after a few seconds/ minutes sometimes it won’t start. What is the solution to this problem?
DoubleA wrote:
On 1/13/2021 at 12:03 PM, DoubleA said:Hello fjacquette,
Back to home depot I go.
Yup
my chain saw has been used less than 10 min and now only works intermittently, about 5 seconds between 5 minute breaks. I gave up when it just stopped completely after about 5, 5 second spurts.
I’m returning it, but suggest buyers beware! For the money I paid for saw, battery, charger and oil, I can say this was one of the most disappointing purchases I’ve ever made.
I just purchased one and have the same problem. The bar oil is in there, the 6ah battery is fully charged (both of them) I switch them and have the same problem. Can someone from Ryobi, look into this. I too am off to homedepot to trade in for another…
Quite a number of posts concerning the same issue #Ryobi #PoleChainsaw #RYOBIFAILURE
