What gear oil in Hitachi H65-SD2 Demolition Hammer
Jack of all Master of noneMember since Mar 2020
I have a Hitachi H65-HD2 demolition hammer drill that I am working on.  The old manual for it does not show what oil to use in the gearbox.  The newer models look like they use a grease, not an oil.  Any help would be appreciated.
Thanks in advance.
Tom
methodMember since Aug 2018
Any type of gear oil should work, it will not be critical to use the manufacturer specific oil. Just check the viscosity of the existing oil and pick a thin or thick oil based on the feel of it.
steve sandellsMember since Jun 2020
Similar to last query, I have a H65SB Hitachi jackhammer and it looks like it had grease in the housing assembly. would this be right?
steve sandells wrote:
Anything should work. The idea is to stop seizing and wear. Grease will eventually get hot and melt everywhere doing the same thing as oil. When I cleaned my old metabo grinder, it was also packed with grease in the housing.
