Differences in products in between countries
IdoMember since Jan 2020
Hallo everyone ..
I would like to ask something as it has to do with differences in between same tools but from different manufacture- countries..
There might be a difference as it has to do with general qualitie of a product..but what about performance..?
For example a dtd171 made in China is the same in performance with the dtd171 made in UK or Japan ?thanks for the help..
OranusMember since Jan 2020
Hello everyone,
I’m sorry but I don’t have an answer for your question but another question at the same topic.
I’m looking to buy a Makita impact driver for some basic projects with wood. In the past I used the model DT110D and it was good enough for my work. The Makita model DT110D is manufactured in New Zealand and I could not find this product in Amazon US or in Europe. I found a lot of other models that seems much more proffesional than what I need and thus much more expenssive than what I plan to invest.
Does someone know a model, similar to DT110D, that is sold in the US and Europe?
Thanks for the help!
BiggieMember since Oct 2016
Oranus wrote:
Without doing to much research it looks like the dt110d is just a brushed cxt 12v which in the US it looks like it would be a dt03z.
stefcl100Member since Jan 2018
Ido wrote:
On 1/8/2020 at 8:47 PM, Ido said:
Hallo everyone ..
As long as their model names are the same, I would not expect much of a difference performance wise. Blueprints are mostly the same and they must comply with the specifications on the product sheet, you should not expect less than advertised.
Even durability doesn’t obey a straight logic, it has a lot to do with the quality of the various parts used for assembling the final product. There can be good and problematic series, you can never tell.
Biggie wrote:
Thank you very much! It helped  🙂
