TS2410LS table saw
Archived from the Tools In Action forum (Ridgid). This thread is read-only.
Steve HoareMember since Nov 2019
Cannot raise or lower blade. Cleaned bevel gears and threaded rod, no difference. Trying to remove height adjustment shaft (the one with handle on 1 end and gear on other). I removed snap ring on the gear end but cannot pull shaft out. Anyone know the trick? Thank you
