Any body had any issues with there hilit 22 sid impact drill mines is cutting off when I press t he trigger battery is all good any help would be appreciated if thanks
Is there a dead spot in the trigger, or does it just cut out after a certain point?
Common fault with them. Mines just gone the same. Pull the trigger and the lights come on but doesn’t spin. Iv had a guts full of hilti if I’m onest. Just constant repairs.
Patrick wrote:
On 11/1/2019 at 5:47 PM, Patrick said:Common fault with them. Mines just gone the same. Pull the trigger and the lights come on but doesn’t spin. Iv had a guts full of hilti if I’m onest. Just constant repairs.
A posted this years ago and only just searching as came across my hilti impact again thanks for your replay…what repaire would you recommend thanks
HiltiWpg wrote:
On 10/23/2019 at 1:13 AM, HiltiWpg said:Is there a dead spot in the trigger, or does it just cut out after a certain point?
It light up then dose not spin and cuts out
