air grinder
346Member since Aug 2019
I have a cheap HF air grinder. Straight. Is there any way to mod it into an angle grinder for use with the little 2 inch scotch pad discs..?
paulengrMember since Sep 2018
Uhh attach a piece of wood to it with say hose clamps but no matter what you do the tool is just plain going to be severely out of balance. If you want an air angle grinder buy one. They are so cheap just the materials to mod a straight grinder blows up your budget. Can’t you by a cheap Campbell off Amazon or Walmart for $25? It will be far better.
I parked the compressor permanently off the truck two years ago. I think the last job we used one was for impacts on a job with 1-5/8” bolts 3 years ago back when 150-200 ft-lbs was it for cordless while air impacts were at 600 ft-lbs. Now with Milwaukee’s cordless at 1400 ft-lbs the air tools are retired on our crew. There are still lots of uses but angle grinding not so much.
