Hi! How to clean hedge shears?
Welcome to the forum.
Assuming the question is about the steel blade surfaces, I have found that a hand-held loose utility knife blade (without the utility knife) is an excellent implement for scraping a surface clean.
Cleaning scissors is not a very difficult process, the main thing is to do it correctly. Because sometimes the scissors get very clogged and very uncomfortable to work with afterwards. I had this problem all the time, it really slows down the work, and cleaning it is not hilarious very convenient, it makes the work very easy. I hope I helped you with my information. A very good old friend of mine gave me some very good advice. He advised me to get a pruning shear with a special metal insert, with which they clean themselves, that is, you just move this to work very easy. Bert and in fact, the scissors become clean. It’s really very convenient, it makes the work very easy. I hope I helped you with my information.
Cleaning your hedge trimmer blades is as simple as wiping them down with soapy water and a cloth after each use. Applying a lubricant to the blades after cleaning is also recommended. Try not to leave it too long between cleans and ideally, after every use is best.
