I have replaced the switch and still no power. I suspect the speed control board.
Can I short out/disconnect the board so that the unit runs at full speed all the time? If so how? I do not want to spend the money for a new board after wasting it in a switch and the variable speed feature is not important to me. Thanks for help.
Frank
I have a Bosch Model 1582 Barrel grip and a power off issue I thought had to be the trigger assembly ended up being the power cord, shorting out where it entered the saw.
The saw was almost never used, no sign of wear near the cord entrance. Will wiggle and try, just to be sure. Thank you.
I pulled up the parts breakdown on e replacements and it looks like the trigger feeds some some kind of range limiting board with a knob adjustment. Power directly to the motor should run it BUT your trigger is a speed control, not an on-off switch. That still leaves you without a power switch to run it at full power. I am sure you want some safe, convenient way to start and stop it. It could be the board but that is a hit or miss way to fix something. It is hard to troubleshoot on line so I hesitate to tell you what to do. A multimeter is the normal way to see where you lost power. Eyeballing will not always find the problem. If you are not comfortable measuring AC, stay out if there. One thing you might try us exercising the knob on the speed board. They can get flakey.
Just had the same failure, on a GST 90BE, so posting this for reference for others.
Yes, you can bypass the the speed controller, and the switch will still work. Remove it and join the white wires and the black / blue wires. Soldered and sleeved in heat shrink tubing.
You should also add a 0.1mF X2 250v suppression capacitor across the 2 power lines, or you will get excessive sparking from the brushes.
The thin wires with the plug on the end can be left, they are the trigger speed control lines.
