just bought a 5 inch fesstool rotex sander. i’m wondering if anyone on this forum uses this sander and can tell me about it. i’ve only tried it a few times so far. when using it in the rotary mode, it can make a grumbling, almost rattling sound that comes and goes as you put pressure on it and then let up.
I have the 6 in version and it is a noticeable difference between having gears engaged vs disengaged. Also it has a 5 mm oscilation on the 6 in where the 5 in only has a 3 mm. One thing I have found is Rotex mode generates a ton of caking on the sandpaper if you don’t have proper dust collection. Also is sands faster and extends the life of the paper when hooked up to a good vac.
so jronman, are you saying that your 6 inch rotary sander does make a grumbling sound when you use it in the rotary mode ?
yeah it is the gears.
That sound is the sanding Festool gods raining unholy hell upon what lay beneath the Rotex. I have a Rotex 150 and when you have the gear driven mode on it sounds like a big block V8 with open headers.
