Modern Storage bed build
rrich1Member since Jun 2015
For those that don’t follow me on Instagram…why not? My name is @r2_woodworking. I have been building a storage bed to match the modern chest of drawers and night stand that I built for my oldest son. This build has taken longer than I wanted due to holidays, weather, new shop upgrades, and broken garage heater. I am finally on the home stretch. Here is what has happened do far.
I wasn’t able to find plans online for what I wanted so I got dimensions from an Ana white plan and heavily modified them to fit my needs.
The frame is cherry with the panels being air dried walnut. These panels are not resawn and are different boards but almost have a resawn look to them. The head and foot boards were put together with Domino’s. Grooves we’re cut with a router table for the panels.
Next was to make the boxes for the bed to sit on to and the drawers to go in. Plywood and pocket holes fit this need perfectly. The drawers will be flush with the frame so I had to make a face frame. The top of the face frame will hold the bed in. Pocket holes were used again to make the frame and attach it to the boxes.
The boxes are essentially the frame and need to sit on something to distribute the weight of the bed. I made the kick out of cherry to keep it all matching. Pocket holes again hid all of the attachment points. The head and foot boards will hide the butt joints. [External image (uploads.tapatalk-cdn.com), not copied][External image (uploads.tapatalk-cdn.com), not copied][External image (uploads.tapatalk-cdn.com), not copied][External image (uploads.tapatalk-cdn.com), not copied][External image (uploads.tapatalk-cdn.com), not copied][External image (uploads.tapatalk-cdn.com), not copied][External image (uploads.tapatalk-cdn.com), not copied][External image (uploads.tapatalk-cdn.com), not copied][External image (uploads.tapatalk-cdn.com), not copied]
Pic set #2[External image (uploads.tapatalk-cdn.com), not copied][External image (uploads.tapatalk-cdn.com), not copied][External image (uploads.tapatalk-cdn.com), not copied][External image (uploads.tapatalk-cdn.com), not copied][External image (uploads.tapatalk-cdn.com), not copied][External image (uploads.tapatalk-cdn.com), not copied][External image (uploads.tapatalk-cdn.com), not copied][External image (uploads.tapatalk-cdn.com), not copied][External image (uploads.tapatalk-cdn.com), not copied]
With the frame parts essentially done it was time for the drawers. I got the continuous grain pattern I wanted and mapped out the box joints I wanted. I cut the box joints on the band saw. Somehow I messed up on the second set and cut on the wrong side of the line….for all of the drawers. Luckily when I trimmed the drawers to fit I had slivers of the walnut. I sanded them down on the drum sander and cut small pieces for patches. This turned out pretty well. Not perfect but these will be at shin level and no one will know.
After getting the drawer glued together #clampchamp I made a jig to router out a handle Instead of using a metal handle. I figured a handle that stuck out would hit a shin or get damages when used as a step. The routed out handle matches the handle I made for the hamper I made so it ties all of the pieces together. [External image (uploads.tapatalk-cdn.com), not copied][External image (uploads.tapatalk-cdn.com), not copied][External image (uploads.tapatalk-cdn.com), not copied][External image (uploads.tapatalk-cdn.com), not copied][External image (uploads.tapatalk-cdn.com), not copied][External image (uploads.tapatalk-cdn.com), not copied][External image (uploads.tapatalk-cdn.com), not copied][External image (uploads.tapatalk-cdn.com), not copied][External image (uploads.tapatalk-cdn.com), not copied]
Currently I am fitting the drawers to the frame. I made runners and slides on the table saw. I had to build up pieces in the frame to accept the runners.
To flush up the box joints I used my hand planes to plane the fronts and sides. They are currently “rough” planed. That is they are all smooth but not flush to the frame. I will go over them again once all of the runners are in and glued and plane the faces flush to the frame and plane the sides, top, and bottoms to give an even reveal. [External image (uploads.tapatalk-cdn.com), not copied][External image (uploads.tapatalk-cdn.com), not copied][External image (uploads.tapatalk-cdn.com), not copied][External image (uploads.tapatalk-cdn.com), not copied][External image (uploads.tapatalk-cdn.com), not copied]
Drawers are all fit and and am currently sanding them. I did a partial sand after doing the rough plane so this won’t take too long. I will need to plane the face frame to the posts and sand them as well. My plan is to put a coat of finish on Monday night. Rubbed one of the faces with mineral spirits to get a glimpse of the walnut awesomeness. [External image (uploads.tapatalk-cdn.com), not copied][External image (uploads.tapatalk-cdn.com), not copied]
Drawers are done with sanding. I planed the face frame to the pillars of the head and foot boards. Up next is to sand the everything.
I also made some much needed f style clamp racks. The larger ones were in my parallel clamp rack and it wasn’t designed for them. I am getting more clamps thanks to William Patrick customs via Instagram I won some jet parallel clamps. So these needed a new home. Not all of my smaller clamps are in the rack as they are currently being used. [External image (uploads.tapatalk-cdn.com), not copied][External image (uploads.tapatalk-cdn.com), not copied]
First coat of General Finishes Enduro var is on. I used my Fuji semi pro 2 to spray it. I have never used this finish before and this is my second project using the sprayer so I actually went over everything with a foam brush. I left the parts that wouldn’t be seen with a spray finish only. I’ll compare and see if the brush is needed. so far so good. Here is a pic of the headboard. I ended up doing the head boards and foot boards by hand only. No room left in the spray booth. [External image (uploads.tapatalk-cdn.com), not copied]
The storage bed is finally finished and my 4 year old loves it. I originally planned to get it finished last month but some shop upgrades slowed the build down a little. The rear drawers will be used for long term storage.
The bed completes the set for my son. The set consisted of a bed, chest of drawers, night stand, and hamper. Instead of using drawer pulls on the drawers I routed in a handle pull like on the hamper. This does two things. 1. It ties the hamper and bed together and 2. It keeps my kids from ripping the handles off, skinning their shins, or using them as steps.
Overall I’m happy with how the bed turned out. The drawers slide easily and my son can get in and out without much issue. He will hit a growth spurt shortly I’m sure anyways.
lyoneMember since Jul 2019
Super impressive!
lyone wrote:
Super impressive!
Thanks!
I need to start a new thread for my current bedroom set build for my daughter.
