Just purchased a 1150 drill press with the production table. Its missing the crank raising handle. Like to find replacement or maybe a picture of one and will fab it. thanks
I just googled it and the first Youtube video for the 1150A shows the table being adjusted with an adjustable wrench. To have a crank you have to have a gear rack on the post and a pinion gear on the table. The 1150 appears to have neither. The table is adjusted with a simple pinch bolt. I checked another 1150 video and it appears to be the same thing. If you have something different post pictures. If you have the gearing it should be pretty obvious what type of coupling would be needed to engage the pinion gear. There are all sorts of cranks and handles at MSC.
