Used Lathe parts
QuickyMember since Jan 2019
I have acquired an old Lathe.  It looks to me to be an old Rockwell or Delta but I can’t find any Model or Part numbers.  I h
need to get new speed controller lever etc cause the speed falls off when you set it up.
Any body know how to find this model for parts?  should I take a bunch of pics of the parts I want?   HELP…
rrich1Member since Jun 2015
Check vintagemachinery.org and it’s sister site owwm.org. owwm is the forum side and VM is more research. You can search via company and tool. Should be a to find any info you need.
Very nice lathe. Would like more pics.
Etech33Member since Feb 2019
Carl,
I found this on through images from vintagemachinery.org. Good luck on the parts. Check out your local wood turners clubs in your area for some one who may have knowledge of older lathes. Another resource could be “WoodCraft”. Some of the staff are usually fairly knowledgeable.
ETech33
