Makita Charge Indicator light
emr42814Member since Jan 2019
Hello I’m new to this forum. I have a question regarding my BL1840B 18V li-ion battery. So this model battery has the star protection feature and so does my XDT11R Impact. I Noticed when I press the charge level indicator button on the battery itself to read how much juice is left so I can charge it and instead of showing me the charge level, it illuminates 2 bars on the left and 2 bars on the right flashing in pairs left to right. When I plugged it into my impact drill, only the LED lights turn on when I press on the trigger. So I tried plugging it in to the charger and it wount accept it. Can Anyone Explain why my battery is acting weird illuminating left to right ??(Again Not The Charger. Battery has its own charge level indicator light on the battery itself) [External image (uploads.tapatalk-cdn.com), not copied][External image (uploads.tapatalk-cdn.com), not copied][External image (uploads.tapatalk-cdn.com), not copied]Idk what the hell is wrong with this battery, Thanks in advance. I just don’t want to throw away a 200$ battery if it can be fixed
ToolBaneMember since Jan 2018
Battery is FUBAR. Contact Makita customer service.
PNWtooljunkieMember since Dec 2016
Yup, battery had malfunctioned. Here’s a shot from the owners manual
MaKetilMember since May 2021
Hi emr,
Did You get repair help?
I have a battery w similar blinking, 5A. Opened the case and checked voltage, all good. Hence, pcb is gone.
Where can I buy a replacement pcb fit to 1850b 5A , anyone?
Thanx!
MaKetil
mikkowusMember since Dec 2023
Has anyone come up with a fix for this issue? I haven’t gotten ahold of customer support
glen608Member since Dec 2023
i have over 20 18v batteries   some 3ah some 5 ah all over 24 months old.     i bought 4 new 6ah batteries less than a year ago and 2 of these  have started to double flash.  is there a fault on them ?
Pino77Member since Dec 2023
My BL1850B battery has been at the bottom of the harbor for a few hours. I used a magnet to retrieve the DDF484 drill from underwater. I let the battery drain and opened it up. All the water is now out, but the lights are also alternating in pairs. I opened the battery. The voltage across the cells is 19 volts. The cells seem to be fine. Is it possible to reset the circuit board? (By the way, the DDF484 works again after disassembly and cleaning.)
I opened up one of my batteries that had the double flash and every battery was showing 4.12 v. And for an instant, it will show 19v from the terminals then drop to 1v. or nothing. Has anyone come up with a fix for this? Maybe I could somehow drain the batteries and that would reset things?
moggy007Member since Jan 2024
Hey I have the same issue with my 6ah makita battery. Its hardly been used, but has double red lights flashing each side of the battery indicator when pressed. Voltage is good on the multi meter, reads 20.4v but won’t charge in the makita charger. Has anyone come up with a fix for this issue? They were quite expensive at £90 a battery, so hoping I’ll be able to save it. Thanks
spazmccoyMember since Sep 2024
If voltage is normal but it still won’t charge and displays the alternating flashing lights on the battery itself, there’s a good chance the PCB needs to be replaced. They can be purchased online for $10-$15 through multiple vendors.
tooluserMember since Jul 2024
Quote
This is a very bad advice. If original PCB is “saying” the battery is dead, then it looks like it found a problem in one of the cells. I’d replace the battery if it’s out of warranty.
