New Makita 12V Max CXT Inflator
I like how compact it is compared to others on the market
I haven’t seen any photos of it next to the others available for comparison yet.
SchenzhenSpecialMember since Oct 2017
It doesn’t need one.
The DeWalt is huge and the milwaukee is boxy and designed around the M12 battery, of course the makita is considerably more compact.
Did you know well seasoned artists can draw to scale without a tape measure?
Also, I can’t understand the point of the trigger. Should be able to set it and start, I really don’t like the idea of having to hold the trigger for it to run.
D WMember since Jun 2016
It has 3 x 18650 cells in that battery, so assume the battery is at least 65mm long, probably as long as an 18V battery is wide. It looks compact. Maybe the size of a 12V Jigsaw?
ToolBaneMember since Jan 2018
That’s definitely quite small.
Hopefully that trigger is toggle on/off because it makes little sense to bother putting in an auto-off and digital reader otherwise.
Sometimes it feels like they’re going a little out of their way to ensure their 12V line doesn’t lurch into LXT territory, as there are a few oddball-type tools that don’t strike me as likely to ever see an 18V counterpart.
Which would be fine, especially for a lot of the low-power items.
Thing is here, Makita’s 12V line does not have any impact wrenches that would be sufficient for taking lug nuts off anything. If it had an adapter to allow direct power from a car battery the decision makes more sense, but I don’t see that.
I see they went with the lever style of locking mechanism. I think I prefer the screw style now. The DeWALT may be big but it has a lot more features pack in. You get 12v car adapter storage, dedicated light, high volume mode, high pressure mode, and storage for all the attachments and hoses.
ToolBane wrote:
If by toggle you mean latching, It isn’t. It’s momentary.
In other words, hold to run.
BremonMember since Dec 2014
18v with more convenience features would be a home run. 12v is a mistake.
Bremon wrote:
What sort of features?
Why is 12v a mistake?
Like a high volume mode to inflate air mattresses, etc., and not using a trigger.
12v is a mistake because the adoption rate for 18v LXT compared to CXT is probably in excess of 3:1.
It has a 5 minute duty cycle so it’s never going to be intented to inflate air mattresses.
Adoption rate in this instance is irrelevant, when you said it should have been 18v it would have been to increase performance. You either want it or you don’t.
And seeing as I’ve never seen a CXT tool on a site I can’t imagine many people getting one.
18v would have been another story
M12 and 20v Max are fairly ubiquitous which makes their inflators a smarter choice. Not to mention I already thought the M12 duty cycle was poor; this Makita is even worse.
Looks nice other than having to hold the trigger…how tedious. If the thing is smart enough to shut itself off when proper pressure is reached just have a button toggle it on. Inflating a tire will be such a nuisance having to kneel on the ground the whole time.
Not a trivial qualm but other than that I like it. Love the digital readout. And so compact…
ToolBane wrote:
God knows who thought it was a good idea.
I’ve used a strip of velcro cable organiser to keep safety triggers depressed (Dewalt 20V die grinder and Metabo 18V recip saw). One side of the strip is the “hooks” and the other the “loops”. All you have to do is wrap it around.
I can only imagine it to be some sort of safety compliance issue…they couldn’t have possibly thought it actually made sense
Tx_woodworkerMember since Oct 2016
I have the dewalt 20v max
Inflator. Aired up my side by side when I had a flat in the middle of the farm.
spinningreelMember since Oct 2019
I’ve owned this inflator for a few months now.
Pros:  Very compact and lightweight profile.  Easily fits under a car seat, easy to take out on ATV/Side by side.  Don’t be fooled by it only using a 12v battery.   This thing will run great on 12v.  I have both 2.0 & 4.0 amp hour 12 v batteries, I have yet to see anything in normal usage that the 2.0 amp hour battery cant perform.
Cons:   Only one, no trigger lock.
I sold my Dewalt 20vmax inflator when I switched brands over to Makita.  That said, I still prefer the Makita even without a trigger lock over my previous Dewalt inflator.   Its just so much more compact and lightweight.
