Milwaukee radio playing up
TrickyMember since Dec 2018
Have a m18 Milwaukee radio and I can get onto Bluetooth and plays music for about 5 minutes then stops. Then I press play again and it stops astaright away.
Also the on/off/volume button stops working sometimes and doesn’t turn off or volume can’t change. This a faulty product or am I doing something wrong?
Thanks in advance 👍🏼
Sounds faulty but needs more trouble shooting. Does it have issues on the radio or a plugged in source? Different phone? Does the phone work with other devices? Do you have other electronic noise going on at the same time? (Example: My BT headphones don’t work when I’m using my EGO string trimmer)
Phone works with other devices, works all the time the radio except Bluetooth.
Connects fine but but then drops out after 5 mins. It’s weird.
methodMember since Aug 2018
If you still have warranty, save yourself time and just return it.
Sounds like interference but that’s not to say that there isn’t something wrong with it. BT circuits can be testy.
