Router/trimmers
Robin MarchMember since Oct 2018
Hello,
Some hand trimmers are available with the ability to be converted to a plunge router (Von Haus, Bosch and Makita). I have the Ryobi 18volt +1 system and am disappointed to see that the 18Volt battery trimmer doesn’t have a plunge accessory available. Does anyone know if the plunge kits from the other brands would fit the Ryobi as certainly they look about the same size?
Thanks
rrich1Member since Jun 2015
i doubt any will fit. routers usually have their own design for raising and lowering the router in the base.
methodMember since Aug 2018
You would be much better off having a dedicated plunge router for the accuracy with depth stop etc. You can buy them reasonably cheap these days if you aren’t worries about a large style or certain brand.
