Guild modern chest of drawers and nightstand
rrich1Member since Jun 2015
I started my son’s chest of drawers and night stand today. These will match the hamper I made in back in March. It will be a cherry frame with walnut sides and drawer fronts.
I didn’t get a pic of all the wood and me trying to figure out which pieces will come from what boards. From the 8/4 boards I figured out the best layout that would yield me the best excess material. A few cuts got a little close so hopefully I meet all of my dimensions.
After layout, which took forever, I cut the pieces out on the bandsaw. I wanted to leave as few pieces as possible so that I wouldn’t be wasting wood off the bat but I decided to cut each piece out. Doing this I should eliminate any surprising twist after I let these sit for a day. Wood stress usually happens when cutting thick boards so hopefully if any movement happens it occurs now and not after final dimensioning.
Pic of the hamper for example. [External image (uploads.tapatalk-cdn.com), not copied][External image (uploads.tapatalk-cdn.com), not copied][External image (uploads.tapatalk-cdn.com), not copied]
2hrs of jointing and planing and everything pretty much looks the same…ugh. up next is cutting to length and starting the mortises. [External image (uploads.tapatalk-cdn.com), not copied]
No shop time the past week. I had to help my mother move out of her house.
I got half of the Domino’s mortised out. Each joint still needs one more cut. I couldn’t help myself and had to out it together to get the feel of the size of the pieces. Hopefully tomorrow I’ll get the other mortises cut. [External image (uploads.tapatalk-cdn.com), not copied]
Second set of mortises cut.
Up next is the grooves for the side panels and I have to make a jig to route out the mortises for the web frames. Into the legs. [External image (uploads.tapatalk-cdn.com), not copied]
Today I got the panel grooves cut for the nightstand. Tomorrow I’ll get the chest of drawers done. Then make the jig to route out for the web frames to insert into the legs. [External image (uploads.tapatalk-cdn.com), not copied]
More progress today and a setback at the same time. I did a dry fit of the pieces again and realized I didn’t route out the dado for the top panels. I’ll need to set the router table back up and do that.
I did manage to make the jig for the router to route out the spaces for the web frames to insert into.
Next I started to work on making the panels. The walnut was all the at the bottom of the cherry pile so I had to dig them out. The plans call for 1/2″ but my walnut is slightly over 1″ now. With resawing, jointing, and sanding I believe I can get 3/8″ and I’m fine with that. The boards I have are over 11″ wide so to joint them I had to rip them down the center. This will give me an extra glue joint but it will be fine. Those two pieces got resawn and are currently in two sets of clamps. I’ll run them through the drum sander to get them closer to equal thickness for the final glue up. Reason for me doing it this way is the bandsaw wasn’t perfectly centered on the board so it would be hard to get cauls to work to keep one face flat of the other sides are not equal. [External image (uploads.tapatalk-cdn.com), not copied][External image (uploads.tapatalk-cdn.com), not copied][External image (uploads.tapatalk-cdn.com), not copied][External image (uploads.tapatalk-cdn.com), not copied][External image (uploads.tapatalk-cdn.com), not copied][External image (uploads.tapatalk-cdn.com), not copied]
Solid progress today. Could have been more but I needed to mow the lawn.
Last night I got the chest of drawers top panel pieces glued up.
Today I got the rest of the panel pieces cut, ripped on the band saw, jointed, planed, and are resting right now. Tomorrow hopefully I can get these resawn on the band saw and get a few pieces glued up. If you do the glue up right they essentially look like a larger piece that was resawn and bookmatched for the panel.
Each panel takes two pieces that have to be resawn to get the width that is needed and save on waste.
Resaw day today. I resawed the rest of the panels and drum sanded one panel to get them relatively flat so cauls to keep the joints flat in glue up. I might try and do another when I get home tonight but I have to work OT tommorow at the illini football game.
If you haven’t gotten at least a few hand planes I highly recommend them. The saw marks were not very good for glue up. A few passes with the LAJ and they were glass smooth. [External image (uploads.tapatalk-cdn.com), not copied][External image (uploads.tapatalk-cdn.com), not copied][External image (uploads.tapatalk-cdn.com), not copied][External image (uploads.tapatalk-cdn.com), not copied][External image (uploads.tapatalk-cdn.com), not copied]
Been a while since an update.
All of the panels are glued up, sanded to 180, and cut to length. The night stand panels have the rabbets cut and everything fit into place. The rear panel is made of maple ply and will be painted like the hamper I already made. Right now I am working on the rabbeting the panels for the chest of drawers. I’ll finish those and cut the rear panel tonight after work.
If you don’t have a cabinet scraper I recommend one. They work great to clean up glue joints.
Also the other day my drum sander conveyor belt broke. Luckily I ordered a new one and it arrived the previous day. I took the time to clean up the rusty metal pieces to clean everything up.
Up next is the web frames. [External image (uploads.tapatalk-cdn.com), not copied][External image (uploads.tapatalk-cdn.com), not copied][External image (uploads.tapatalk-cdn.com), not copied][External image (uploads.tapatalk-cdn.com), not copied][External image (uploads.tapatalk-cdn.com), not copied][External image (uploads.tapatalk-cdn.com), not copied][External image (uploads.tapatalk-cdn.com), not copied][External image (uploads.tapatalk-cdn.com), not copied]
Chest of drawers is up. And the main pieces are fitted. Up next is sanding everything. Then I will glue the sides together. This will help me get better measurements for the web frames.
I purchased some total boat clear epoxy and it arrived yesterday but it is missing one of the pumps. [emoji849][External image (uploads.tapatalk-cdn.com), not copied][External image (uploads.tapatalk-cdn.com), not copied][External image (uploads.tapatalk-cdn.com), not copied]
The night stand is sanded to 220 with a seal coat on. I’m loving this air dried walnut. It really pops with the finish on it. The dresser frame is sanded at 150. I still need to sand the panels. I think I am going to wait until Monday for the sides to be glued/epoxied together. I want to buy some thickener for the epoxy so it won’t be so runny. [External image (uploads.tapatalk-cdn.com), not copied][External image (uploads.tapatalk-cdn.com), not copied]
So I got everything sanded…which took a while. Last night I attempted to glue up the night stand sides but I messed up the epoxy ratio as I didn’t have both pumps. Today I tried to clean out the epoxy that didn’t set up and weighed out the epoxy this time. I only did one of the sides of the night stand. Wasted epoxy but if this works I will go ahead and do the other side of the night stand and chest of drawers [External image (uploads.tapatalk-cdn.com), not copied]
khariVMember since Dec 2014
You use epoxy for glue ups?  Why not titebond?
Khari good question. The reasons why I went with epoxy are:
1. Longer open time than yellow glue.
2. I have never used epoxy before and wanted to try it.
3rd and most important it is gap filling. Even with the Domino’s I had to shave a little off of some of them to get fitted flush on the bottom and top of the pieces. The epoxy will fill those gaps and hopefully give me a stronger joint than if just normal glue.
4. Marc did it in the vid and I have to be cool like him.
Interesting.  I might have to read up on this to address some of my own “well, that doesn’t quite fit as tightly as I’d like” joints.  My only concern would be getting it everywhere as the two kinds of epoxy I’ve got (West and SystemThree) are so runny, it’d make an unholy mess.
I bought some 404 filler as well. This thickens it up. Add as much as as little to get the consistency you want.
https://www.rockler.com/west-systemreg-epoxy-filler
Wow – I’m such a nub. I wish I had known about this when I was using epoxy to repair water damage on laminate countertops at a cat shelter I volunteer at.  As it was, the thin epoxy ran everywhere and made a colossal mess that I had to clean up.
Ha! I’m obviously new to it as well.
The pump came yesterday but I didn’t have time to glue anything up last night due to getting out of work late. I’m picking my son up from preschool here soon and will get them glued up while he is eating lunch.
@khariV here is a pic of the epoxy with the adative. I could have put more in it but felt that was as far as I wanted it to go to not be a paste.
I got the other side of the night stand glued and one side of the chest of drawers before the epoxy was too stiff. If I double checked all my Domino’s on the chest of drawers before hand I could have probably gotten to both sides. Oh well. I’ll do the other side before work or after. I won’t get to work on these again until Sunday anyways.
On Wednesday I did get all of the web frame material jointed and planed. Will cut to final dimensions when these panels are glued up. [External image (uploads.tapatalk-cdn.com), not copied]
Last side panel is epoxied and in clamps. I also filled two knots with black tinted epoxy. Those were on the top panel of the night stand.
Big progress today. I was able to get a few hours of shop time in after church and after the in laws came over for supper. Today I was able to get all of the web frames cut out and dimensioned. Somehow I originally miscounted the sides of the frames and was short by 4. I had to dig around for scrap and I was able to find some pieces of cherry that would work. I didn’t feel like cutting up a piece of lumber which would have been quicker. Up next is to domino all of the jointed of the web frames and glue them up. With the domino basically being a router I don’t like to run it so late at night. I’ll then be able to get it back to my friend since I have had it a month. Lol [emoji1787]. If you look close the front and rear pieces have tennons cut out of them. This is what took these so long to make.
Tomorrow I will also paint the back panels so I could theoretically glue these things up on Tuesday or Wednesday. [External image (uploads.tapatalk-cdn.com), not copied]
Went frames made and the pack panels are painted. Tonight after work I made the runners that the drawer slides on. I also started to round over the mortises of the web frames. These slide into the slots of the chest of drawers and night stand legs. [External image (uploads.tapatalk-cdn.com), not copied][External image (uploads.tapatalk-cdn.com), not copied][External image (uploads.tapatalk-cdn.com), not copied][External image (uploads.tapatalk-cdn.com), not copied][External image (uploads.tapatalk-cdn.com), not copied]
Glued and nailed on the runners today. The night stand fit on the first try. I also put another coat of paint on the backs. Getting a lot closer!
I could have gotten more done but I started a side project yesterday. A doll bunk bed for my daughter. Making it out of left over hickory from the workbench build. [External image (uploads.tapatalk-cdn.com), not copied][External image (uploads.tapatalk-cdn.com), not copied]
Dry fit. Glue up will commence after work tonight. [External image (uploads.tapatalk-cdn.com), not copied][External image (uploads.tapatalk-cdn.com), not copied][External image (uploads.tapatalk-cdn.com), not copied][External image (uploads.tapatalk-cdn.com), not copied]
Hopefully I didn’t forget anything. Night stand is epoxied together. I cut the lower runner but haven’t attached it yet. [External image (uploads.tapatalk-cdn.com), not copied]
Chest of drawers is glued up. Up next is picking the lumber for the drawers. [External image (uploads.tapatalk-cdn.com), not copied][External image (uploads.tapatalk-cdn.com), not copied][External image (uploads.tapatalk-cdn.com), not copied][External image (uploads.tapatalk-cdn.com), not copied]
Few more pics of the chest of drawers. Also I mapped out the lumber for all of the drawers. A whole lot of lumber. The walnut piece on the right is just under 13″ wide. [External image (uploads.tapatalk-cdn.com), not copied][External image (uploads.tapatalk-cdn.com), not copied][External image (uploads.tapatalk-cdn.com), not copied][External image (uploads.tapatalk-cdn.com), not copied][External image (uploads.tapatalk-cdn.com), not copied]
Alright…it’s been a while since an update.
I planed all of the drawer pieces to thickness and rough cut them to length and width.
To aid with making the box joints for the front of the drawers I made the ultimate box joint jig by ibuildit.ca. I’ll use a band saw to make the cut lines and then use the box joint jig to gog out the waste. Jig works well when you remember to change the height setting between pieces. I’ll use a dado stack next time though to go faster. [External image (uploads.tapatalk-cdn.com), not copied][External image (uploads.tapatalk-cdn.com), not copied][External image (uploads.tapatalk-cdn.com), not copied][External image (uploads.tapatalk-cdn.com), not copied][External image (uploads.tapatalk-cdn.com), not copied][External image (uploads.tapatalk-cdn.com), not copied]
First drawer front. Kinda irritated. Somehow my marking gauge must have moved and made my line deeper than it should have been. My test cuts before were perfectly flush. [External image (uploads.tapatalk-cdn.com), not copied][External image (uploads.tapatalk-cdn.com), not copied][External image (uploads.tapatalk-cdn.com), not copied][External image (uploads.tapatalk-cdn.com), not copied][External image (uploads.tapatalk-cdn.com), not copied]
They look good though dude. Are you going to fill them or sand them or leave them in place?
What I think I am going to do is take a router and use the gap on the front (the space the sides fall short of reaching the front) and then flip the piece over and route the back sides of the drawer front box joints. This will flush up the fronts. Then on the sides I’ll glue them up and use a flush trim bit.
I got all of the dresser drawers sized today. Aside from the backs being cut to length. I couldn’t be happier so far. I will need to fill a spot in the bottom front piece with some epoxy [External image (uploads.tapatalk-cdn.com), not copied]
Awesome idea bro, that’ll work slick as snot
Lot of work done the past two days.
I got all of the drawer fronts and sides of the dresser marked out and cut. First the band saw to establish the outer lines of the cut and the the box joint jig to cut the waste out. I didn’t get a chance to chisel them out until today. I don’t like hammering that late at night. These joints fit PERFECT! A nice snug fit and essentially flush. So much happier with these joints than the joints on the night stand.
I also filled some knots and splits in the wood with epoxy. I used clear for the cherry pieces and tinted it black for the walnut piece. Pics of before and after I scraped the epoxy with a card scraper.
Today I cut the dados for the backs and trimmed the runner guides to width. My dado stack wasn’t quite a 1/2″ for the back dado so I used the drum sander to finesse them to the right fit. Having the drum sander for this build has been awesome. [External image (uploads.tapatalk-cdn.com), not copied][External image (uploads.tapatalk-cdn.com), not copied][External image (uploads.tapatalk-cdn.com), not copied][External image (uploads.tapatalk-cdn.com), not copied][External image (uploads.tapatalk-cdn.com), not copied][External image (uploads.tapatalk-cdn.com), not copied][External image (uploads.tapatalk-cdn.com), not copied]
Dados for the bottoms are routed in. Stopped dad is for the fronts [External image (uploads.tapatalk-cdn.com), not copied][External image (uploads.tapatalk-cdn.com), not copied][External image (uploads.tapatalk-cdn.com), not copied]
Simple fix to a dumb mistake. I managed to move my marking gauge when I did the scribe line on the nightstand drawers. This made the sides short of the face of the fronts.
To make this a simple fix I got the depth needed for my router bit from the recess on the front. Then I used a marking gauge to sever the word on the back side. I then took the router and routed out the wood needed to make the sides flush with the front. This worked amazingly well and took no time at all.
I also got all of the drawer bottoms cut. I started to sand and sanded all of the interiors of the drawers. [External image (uploads.tapatalk-cdn.com), not copied][External image (uploads.tapatalk-cdn.com), not copied][External image (uploads.tapatalk-cdn.com), not copied]
The last drawer is currently in glue up. I planed and sanded some of the drawer joints. Didn’t turn out too bad. I didn’t get some of the bottom cherry sides pushed in all the way so there was a decent amount of planing there. Overall happy so far. [External image (uploads.tapatalk-cdn.com), not copied][External image (uploads.tapatalk-cdn.com), not copied][External image (uploads.tapatalk-cdn.com), not copied][External image (uploads.tapatalk-cdn.com), not copied]
Chest of drawers and night stand update.
I planed the case smooth at the joints and then planed the drawer fronts to the case front. I also installed the drawer runners prior to planning the drawer front down. I sanded to 120 so far to give myself a good surface to measure for the drawer pulls. I drilled for those today and installed the pulls for now. Up next is more sanding to 180 or 220. I also need to fix a small chip out on the front rail that occurred when planing. [External image (uploads.tapatalk-cdn.com), not copied][External image (uploads.tapatalk-cdn.com), not copied][External image (uploads.tapatalk-cdn.com), not copied]
Everything is sanded and the drawers got sanding sealer put on. I am attempting to fox some tear out on the front top of the chest of drawers. I used a chisel to get it pretty flat. I then glued a piece of scrap wood onto it. That is where it currently is at. I will then chisel it and plane it smooth. [External image (uploads.tapatalk-cdn.com), not copied][External image (uploads.tapatalk-cdn.com), not copied]
Had to fix some tear out on the top right front joint of the chest of drawers. I chiseled it smooth then glued a patch on. After the glue dried I planed and sanded it smooth. While not a perfect repair job it is definitely better than missing wood.
Today I also put sanding sealer on the night stand and chest of drawers. All that’s left is to sand it and apply the coats of finish. I am going to spray them with general finishes Enduro var. It’s a water based poly that is supposed to give the appearance of an oil based poly. [External image (uploads.tapatalk-cdn.com), not copied][External image (uploads.tapatalk-cdn.com), not copied][External image (uploads.tapatalk-cdn.com), not copied][External image (uploads.tapatalk-cdn.com), not copied][External image (uploads.tapatalk-cdn.com), not copied][External image (uploads.tapatalk-cdn.com), not copied]
Makeshift spray booth. I used the rails of the garage doors for the spray booth. It worked out really well using spring clamps.
I initially tried to spray general finishes Enduro var but then I realized the can says to not use on sanding sealer. [emoji17]. Luckily this was my first time spraying with the Fuji semi pro 2 hvlp and I only started on the bottom side of one drawer. After deciding it wouldn’t work, I switched to arm r seal. This worked much better. I applied a coat to one drawer, the chest of drawers, and the nightstand. If I was thinking I could have done another drawer. Oh well. I definitely preferred the Enduro var to the arm r seal for spraying…mist wise. The Enduro var was just cleaner. The arm r seal sprayed great but just messier overall. I do have some runs that will hopefully sand out but we shall see. [External image (uploads.tapatalk-cdn.com), not copied][External image (uploads.tapatalk-cdn.com), not copied]
Guess who put the last coat of poly on today? That’s right…this guy!
Soooo close! Will wet sand and wax this weekend. Still need to shampoo the floor before moving the furniture in anyways.
Finished! Three coats of arm r seal (2 semi gloss and 1 satin). Finished by wet sanding with 600 grit and buffed with paste wax and 0000 steel wool. [External image (uploads.tapatalk-cdn.com), not copied][External image (uploads.tapatalk-cdn.com), not copied][External image (uploads.tapatalk-cdn.com), not copied][External image (uploads.tapatalk-cdn.com), not copied][External image (uploads.tapatalk-cdn.com), not copied][External image (uploads.tapatalk-cdn.com), not copied][External image (uploads.tapatalk-cdn.com), not copied][External image (uploads.tapatalk-cdn.com), not copied][External image (uploads.tapatalk-cdn.com), not copied]
