Simple Wal it cross
rrich1Member since Jun 2015
Made a simple Wal it cross as a thank you gift. Build/milling time was probably around 1.5hrs. that included figuring out the right dimensions. The top edges are chamfered and I really like where the two pieces meet. They are connected via a half lap joint. It will be hinges using a key hole slot. It was the first time I got to use my new touch mark from my branding iron. The touch mark is an abbreviated mark of the full design. The R2 stands for my initials. [External image (uploads.tapatalk-cdn.com), not copied][External image (uploads.tapatalk-cdn.com), not copied][External image (uploads.tapatalk-cdn.com), not copied][External image (uploads.tapatalk-cdn.com), not copied][External image (uploads.tapatalk-cdn.com), not copied][External image (uploads.tapatalk-cdn.com), not copied]
