Can’t wait to buy these!!! they are out now at home depot and other outlets
James Duncan wrote:
On 7/11/2018 at 12:56 PM, James Duncan said:Can’t wait to buy these!!! they are out now at home depot and other outlets
They are great, if you are using a holesaw or larger bit in hard wood, I recommend spending the extra $ for the hard case and the side handle…I wish I had. Now I need to buy the side handle separate. That little drill has so much torque I could have seriouslu hurt my hand.
So the new gen 3 drill doesn’t come with a side handle?
AnonymousJoe wrote:
3 hours ago, AnonymousJoe said:So the new gen 3 drill doesn’t come with a side handle?
According to Milwaukee, the 2705-20 (Bare tool) comes with the side handle, so it should have been in the box.
https://www.milwaukeetool.com/Products/Power-Tools/2705-20
Bare tool 2803/2804 should come with a side handle and belt clip.
First impression of the drill is I can’t believe how small it is for the power it has it feels like a compact drill. I got a 2803 drill/driver and chuck jaws don’t have the carbide inserts. Also for all the people hopeful that the new drills would have a rohm chuck it definately is not. I would say the knurl pattern has more grip to it and the sleeve itself doesn’t feel as flimsy as on previous chucks. While it’s not important to me I find it kind of strange that no ones made any mention of the electronic clutch.
SpruceHill wrote:
On 7/12/2018 at 5:41 PM, SpruceHill said:They are great, if you are using a holesaw or larger bit in hard wood, I recommend spending the extra $ for the hard case and the side handle…I wish I had. Now I need to buy the side handle separate. That little drill has so much torque I could have seriouslu hurt my hand.
what model# did you buy?? the one im seeing all over comes with a side handle and a hard case Model # 2997-22 are you sure you bought the brand new ones?
https://www.milwaukeetool.com/Products/Power-Tools/Combo-Kits/2-Piece-Kits/2997-22
Biggie wrote:
On 7/13/2018 at 10:18 PM, Biggie said:Bare tool 2803/2804 should come with a side handle and belt clip.
The 2804 is the same size as the brushless compact Dewalt, the DCD791. It’s insane. I want to wait to see what Dewalt has in the pipe but a 2803 is in my sights. The chuck was explicitly described at NPS18 as not being a Rohm but it’s supposedly a nice one lol. “Milwaukee-designed”. They’re quite proud. We’ll see.
A lot of torque for it’s size! Impressive.
Weight is 3.2lbs (1.45Kg) tool only, according to Milwaukee.
The drill looks to be better in almost every way. The one thing that concerns me is the cooling. I have noticed the vents look smaller. I thought I seen about them getting hot but I can’t find any info to backup what I thought I seen.
I think if u shoot YouTube vids and tool fights and run tools trying to max them out then I’m sure they get hot. Everyday use I’ve never had this issue and if I did it’s because I was too lazy to get out my hole hawg or my sds. I agree tho on the small vents. Seems like any tool branded with ‘fuel’ is sealed up with small and/or minimal vent holes. Kinda opposite of what other brands do. Can’t wait to get this drill tho. I’d like to know the specs on the chuck and if it’ll be available for purchase and able to be mounted on the gen 2 drill.
Tool boss did a review with the Milwaukee rep..he said it’s a Milwaukee made Chuck ..and the specs are the same as the previous model only more compact…?
Framer joe wrote:
On 7/16/2018 at 12:20 AM, Framer joe said:Tool boss did a review with the Milwaukee rep..he said it’s a Milwaukee made Chuck ..and the specs are the same as the previous model only more compact…?
Tool boss is wrong .. As per the Milwaukee website:
Quoteboth products also feature new industry-leading chucks with black oxide jaws and an updated sleeve knurl pattern for superior bit retention.
Milwaukees says its a New chuck in this video and theres a chart (i cued up the video to where he talks about the new chuck system
Looks like a Rohm chuck to me?
So the knurled pattern gives u 30% more grip strength… lol I wish they’d cut back on all their percentages sometimes it’s starting to sound so cheesy. Either way I’m on my 3rd bad chuck this year on my gen 2 so I’ll definitely be getting one of these
Now with 30% more marketing wank!
HiltiWpg wrote:
17 minutes ago, HiltiWpg said:Now with 30% more marketing wank!
Milwaukee misleads more with their bar graphs on their packaging than your average politician. I like their tools, but MAN are they fishy.
StrippedScrew wrote:
7 hours ago, StrippedScrew said:Looks like a Rohm chuck to me?
I know the knarling looks like a rohm but when you get it next to a gen 1 or 2 you can tell it’s a milwaukee chuck with a new grip sleeve.
Hmm I’m finding it hard to believe that milwaukee makes their own chucks, but just for one drill? Why don’t all their drills have it then?
Yea I don’t get where they come up with 60% more power and up to 2x more speed under heavy load. My first use with the new drill I had about 60 holes in 2 pieces of 12ga steel. There were 3/8″ holes punched in the steel that were about a 1/4 of a hole off and I wanted to upsize the hole to 7/16″. I was running the drill in high speed as I would on any drill. On all 60 holes the drill would bind one time and shut itself off before drilling through the hole. Now to me this was a pretty heavy load being put on the drill and I’m not really knocking the drill because our dcd996 and gen 2 fuel bind and shut down the same way, I just don’t think it has that much more power. The main reason I wanted the drill was for how compact it was with as much torque as the gen2 and it does deliver on that. On a side note, it did seem to do a good job of holding the bit tight without slipping as I know my 2703 and 2704 would have with all that binding but it’s also a new chuck so time will tell.
Biggie wrote:
2 hours ago, Biggie said:Yea I don’t get where they come up with 60% more power and up to 2x more speed under heavy load. My first use with the new drill I had about 60 holes in 2 pieces of 12ga steel. There were 3/8″ holes punched in the steel that were about a 1/4 of a hole off and I wanted to upsize the hole to 7/16″. I was running the drill in high speed as I would on any drill. On all 60 holes the drill would bind one time and shut itself off before drilling through the hole. Now to me this was a pretty heavy load being put on the drill and I’m not really knocking the drill because our dcd996 and gen 2 fuel bind and shut down the same way, I just don’t think it has that much more power. The main reason I wanted the drill was for how compact it was with as much torque as the gen2 and it does deliver on that. On a side note, it did seem to do a good job of holding the bit tight without slipping as I know my 2703 and 2704 would have with all that binding but it’s also a new chuck so time will tell.
If you didn’t drop the bit once, then that’s a massive improvement over the gen 2 chuck.
BTW, gen 2s chuck was a one-off too, it had an odd thread, 9/16-18. The “standard” is 1/2-20.
I have not heard anything good about a Milwaukee made Chuck over a Jacobs Chuck…….but the gen 3 kit looks amazing
Good deal! Wish they would offer these new tools in packout cases
AnonymousJoe wrote:
56 minutes ago, AnonymousJoe said:Good deal! Wish they would offer these new tools in packout cases
They should do a free tool/packout/battery promo. The packout pieces and batteries are getting near or exceeding the cost of a lot of free tools…I don’t see why they can’t do a packout tote or anything under the rolling base as a promo on kits. Great way to get people into the system. Even if they lose money on the free packout they’re getting someone into that system which means more packout sales.
I was a ridgid guy but after I bought the 12v impact and drill kit an they both out preform my ridgid stuff I have started changing over to Milwaukee unreal stuff they put out I cannot wait to have my whole arsenal Milwaukee
JohnyWalter wrote:
10 hours ago, JohnyWalter said:I was a ridgid guy but after I bought the 12v impact an drill kit an they both out preform my ridgid stuff I have started changing over to Milwaukee unreal stuff they put out I cannot wait to have my whole arsenal Milwaukee
I’ve said this before. We have a corded drill at the shop that we’d use for drilling metal or using spade bits in plastic or wood. My M12 brushed drill is more powerful than that drill…the least powerful cordless Milwaukee! The M12 Fuel (Gen 1) is stronger than my friend’s 20V PC drill and it’s not even close, the M12 brushed is a little more powerful IMO.
Referring back to the heat comments, I’ve had my M28 brushless so hot it was uncomfortable to hold! Never cut out though!
For those who have this set, I have a question: I’ve used both M18 and M12 Fuel drills/impacts (both 2nd gen) and have noticed when feathering the trigger they both let out a shrill, high-pitched noise when feathering the trigger prior to the chucks rotating. Does that happen with these?
I watched a video on YouTube that addressed that issue with the screech and lag in trigger response. Gen 3 seems to have fixed that
aabee wrote:
On 7/30/2018 at 5:37 PM, aabee said:For those who have this set, I have a question: I’ve used both M18 and M12 Fuel drills/impacts (both 2nd gen) and have noticed when feathering the trigger they both let out a shrill, high-pitched noise when feathering the trigger prior to the chucks rotating. Does that happen with these?
I checked on mine and my gen 2 stuff has the noise but it seems to be completely gone on the gen 3 impact and drill.
So yesterday I was drilling some holes in steel 50′ up a tower and my 2803 drill caught and half way twisted out of my hand. I went to put it in reverse and the switch was jamed and wouldn’t move. Thinking the switch was broke I climbed down to get a different drill and sure enough when I got to the ground the switch is working just fine. Not sure what happened that it jamed or when or if it’ll do it again.
I have to say besides that hiccup this drill is really impressing me. I think it’s a combination of more power and a chuck that holds the bit tight, but it definately seems to drill through steel better than the gen 1 or 2. As far as the drill getting hot I haven’t had any issues. I don’t use big hole saws and I haven’t used it to drill 100’s of holes one after another yet, but with regular daily use I haven’t noticed anything out of the ordinary.
AnonymousJoe wrote:
On 7/16/2018 at 4:41 AM, AnonymousJoe said:I think if u shoot YouTube vids and tool fights and run tools trying to max them out then I’m sure they get hot.
Some people work like that all day every day.
On 7/18/2018 at 8:01 PM, StrippedScrew said:Looks like a Rohm chuck to me?
Doesn’t look like any rohm I’ve ever used.
HiltiWpg wrote:
On 7/19/2018 at 2:36 AM, HiltiWpg said:Now with 30% more marketing wank!
Have you seen this brightly coloured bar chart and heard our misleading slogan? Then boy do we have the tool for you!
I genuinely think they’re presuming people will buy them regardless, and it’s true. Some of the hardcore Milwaukee boys will buy anything they put out regardless of quality or cost.
Gen 4 next year….the drill will get smaller and more powerful…
Framer joe wrote:
On 8/25/2018 at 10:35 PM, Framer joe said:Gen 4 next year….the drill will get smaller and more powerful…
im holding out for gen 5, i hear it does all the work for you
