Router bushings can get hot – a cautionary tale
khariVMember since Dec 2014
Perhaps I should call it – “How I hurt myself on a router table when there was no router mounted in the table.”
I was working on a small STEM project for my daughter’s school tonight and  was setting up my router table to route some box joints.  I raised up the bit and apparently got it a bit too close to the inset bushing in the table.  When I turned the router on, it whined a horrible high pitched sound and so I turned it off right away. I pulled the router as I was going to have to raise the bit in the collet so that the nut wouldn’t rub.  Well, when I returned to the table, I noticed that the bushing had rotated a bit and so I went to turn it back to the original setting.
This was not a good idea.  Apparently the metal bushing, from about three seconds of contact with the spinning collet nut had heated up to several hundred degrees.  I had just grabbed it with two fingers and instantly regretted my decision.
I know in the grand scheme of things, if you’re going to get hurt in the shop, burned fingers are a small price to pay to learn a lesson, but holy crap it’s a painful lesson to learn.
So, to anyone else who may find themselves in a similar situation – never assume that just because there’s no router in your router table that you it’s safe to handle.
