Head lights
Jrhky36Member since Nov 2016
Just put some headlights on my scag so i can cut in the dark.
I used rough country’s twin 6″ light bars. Each bar is 6 400 lumen leds. Total out put is 4800 lumens. 12 volt system wired directly to the battery with an in fuse.
I had to make brackets because the ones that came with would not work.
All told it took me about an hour or so to install.
look great. Scags are good mowers. You planing on adding any more?
No dont want to over do the electrical system. I currently use chem lights/ lightsticks on the rear. When i put up for winter i will disconnect the lights from the battery.
