I have been converting my garage into a small shop. I designed it so I could easily move things to make room for both of my parents vehicles when I am done working for the day.
This is storage mode.
The larger table was rebuilt to better fit my needs. was also out of square and is much better than it was. I usually pull out the larger table where I do most of the work. I use the clipboard for my notes and whatnot for the current project. Great for showing where to cut pieces out of the plywood. most of the stuff hanging on the wall is my dads stuff collected over the years.
This is my miter station setup. The vac gets moved around between the tools. The open half of the miter station currently is being used for rough cut pieces for my current project. large clamps and small guide rails go on the wall.
This is a shelf I built from scrap wood from when I rebuilt a work table previously in the garage. Stores smaller items and small clamps. it also is where I charge my batteries and my mom said I needed a clock which is more helpful than I thought.
On the other half of the garage is where I have my various boxes. I also use my blower for cleanup. I got a few Festool boxes, a couple screw boxes which I changed the setup a bit to where i separated the large bins into one box and small bins into another box. I also have screws labeled with sizes and whatnot. I got a couple ds130’s. one for my batteries and another to hold my recip saw and accessories. To the left of the systainer is the back wall where plywood and lumber is being stored.
More boxes and my table saw setup. I made a dust catch thingy from scrap wood and cut a hole in the back to slide the vac hose through. I feel it does a decent job considering the vac hose is smaller in diameter than the saw’s dust port. The ds400 houses extra chargers, kreg k5 jig, and a planer. The ds300 is my “work box”. it holds my drill, impact, light, omt, screw/drill bits, and omt accessories. Not much else worth mentioning in it. the tstak holds my track saw.
You can go ahead and send the rotex and track saw my way [emoji16]
Looks nice man! I don’t miss having not my own garage now I have my own domain although the wife tells me the cars need to fit in winter time [emoji849] so I try to stay modular as well. Nice work man!
Nice setup! I also use my Ego blower to clean up the garage. Blow the remaining saw dust out of the garage and let nature take it’s course.
I typically spill large amounts of sawdust and chips on the floor, I have my RIDGID vac under my bench and enough hose to reach the whole shop. What doesn’t gets vacuumed? EGO baby!
Looks like I’m the odd man out. I use my Makita blower to clean my shop out [emoji16]
Sweet set up dude !!
Yup, vacuum the big pieces and blow the rest out. I blow the tools out with compressed air, the compressor turns on when I flip the switch for my bench work light.
I just go straight to the Ego when I blow off my tools haha. Somethings get a quick wipe with CMT’s cleaner.
Got this guy put up yesterday. Hopefully I can get the second one up today. Used the hammer function on my DCD996 for the first time so I could join the treated 2×4 to the floor. drained my compact pack rather quickly. Had to switch to a flex to finish the job. It was reasonably easy to instal. Hardest part was getting the brackets on and in the right spot. I’m thinking about getting a couple more organizers and trying out the new 3 drawer unit to add to the collection to put some of my dads stuff in them.
Looking sweet!
Nice job on the shared space shop and some sweet tools bro. Sorry I’m just seeing this but keep it updated!
Thanks. I can try and get an updated pic. I got a new spot for the table and I even made space for lumber on the shelves on the side wall. It freed up some space.
That is a nice setup! While having a massive dedicated shop would be ideal, few of us have the resources to make it a reality. You have the makings of an outstanding shop; imagine how great it will be when you have a garage (or workshop) to yourself!
Nice set up [emoji106]
rrich1 wrote:
On 10/12/2017 at 5:21 AM, rrich1 said:Looks like I’m the odd man out. I use my Makita blower to clean my shop out emoji16.png
I EGO my garage out a couple of times a week
Nordraw wrote:
15 minutes ago, Nordraw said:I EGO my garage out a couple of times a week
Basement shop here. My Wife would literally kill me if I did that 👍
ChrisK wrote:
6 minutes ago, ChrisK said:Basement shop here. My Wife would literally kill me if I did that 👍
Nordraw wrote:
23 minutes ago, Nordraw said:I EGO my garage out a couple of times a week
I use the small dewalt 20v, and blow out through garage door each day when I leave !!
ChrisK wrote:
10 hours ago, ChrisK said:Basement shop here. My Wife would literally kill me if I did that 👍
Even if the garage door is down I’ll EGO mine, it’s like a broom…also great for getting the dust and wood off of tools, get it in a general area then sweep and vacuum. Low power of course.
ChrisK wrote:
On 1/1/2018 at 11:40 AM, ChrisK said:Basement shop here. My Wife would literally kill me if I did that 👍
Yeah you have to have the garage door wide open to make that happen.
