Nothing to fancy, but perfect for my needs. Makes feeding pieces of plywood much easier. Still have access to the vacuum port. Table saw can be moved side to side and removed when space is needed. I decided to go this route because the taller piece is going to take place of my work bench… so when I need a bench to work on, I remove the table saw and bam there is my work station!
looks good
I bet it helps a lot with the plywood
nice setup.
Nice job dude. Outfeed too!
