Festool Sandpaper Guide
I figured this would be a good idea.
Example – STF D125/8 P40 GR/10
STF – I’m unsure maybe the way the paper attaches to the sander? in this case StickFix?
D – This indicates diameter
125 – Indicates diameter of the sanding pad in millimeters
8 – the number of vacuum holes on the sanding pad
P – I’m unsure I seen different letters here. Thoughts?
40 – indicates the grit number
GR – indicates the type of sandpaper in this case GR for Granat
10 – indicates the number of sheets in the set.
Festool has many types of sandpaper here are most of them.
Granat –  Versatile, general purpose abrasive for use on wood & finished surfaces.
Rubin 2 – Finish Faster – Rubin 2 is designed to quickly shed wood fibers, eliminating clogging so the abrasive stays sharp, leading to a 30% faster removal rate.
Save Money – Since Rubin 2 is designed to prevent clogging due to the buildup of pitch and wood fibers, you’ll get up to 30% longer life out of every sheet.
Your Best Finish – Designed for rapid grit progression, you’ll spend less time getting from 80 to 220, achieving the best possible finished surface in the least amount of time.
Brilliant 2 – paint, fillers, primers and finishes like lacquers and varnishes; its antistatic coating is compatible with water-based products.
Platin 2 – A foam-backed, silicone carbide based abrasive with a stearate coating specially developed for high-gloss finishes on closed surface materials.
Ideal abrasive for super-fine finish on fillers, finish coats, solid surface, fiberglass and plastics.
Saphir – Durable aluminum oxide abrasive incorporates a tear-resistant fabric backing for longer life in extreme applications.
Ideal abrasive for heavy duty sanding of wood, paint, plastics, fiberglass, composites, concrete and steel.
Vlies – excellent for deep pore cleaning on natural woods, veneers and is great for use on contours. Perfect for cleaning and de-rusting metal.
Diamant – High-performance abrasive for finishing very hard surfaces
Matting and refining hard surfaces such as scratch-proof clear coats and composite and solid surface
Light sanding of panel-type materials coated in melamine resin for preparation of paint application
Titan 2 – excellent for automotive finishes: paints, fillers, primers and lacquers and preferred for all oil-based paints and finishes.
Nice guide here, I’ve used granet and Rubin it’s nice paper, they have a new NET style disc coming out if I’m not mistaken
yeah. I’m guessing it is for drywall sanding.
Nets good for wood working as well, doesn’t clog much and lasts a good life longer than traditional paper
I’ve used Mirka ABRANET on my ETS 150 and have been very happy with it. Its a mesh type of disc, no worry about lining holes up.
I picked some of the new Diablo net up, we’ll see how that works
