We are going on vacation later this month to Cali. My aunt is allowing us to stay at their house for the week just outside of LA. As a thank k you I decided to make them a cutting board. I had some walnut, maple, and padauk on hand. Also some cherry but I haven’t cut any of it. This will be an edge grain cutting board. Here are a couple of designs I messed around with. Thoughts? Favorite? I’m indecisive so input is appreciated. [External image (uploads.tapatalk-cdn.com), not copied][External image (uploads.tapatalk-cdn.com), not copied][External image (uploads.tapatalk-cdn.com), not copied][External image (uploads.tapatalk-cdn.com), not copied]
That is a great idea… I like the last one.. have fun on vacation Cali sounds like would be a good time
@Jscott. Thanks. Ended up going with this one. [External image (uploads.tapatalk-cdn.com), not copied]
That’s the one I liked the most. BTW, congrats on the IG giveaway win Rich!
Are you talking about one of builybyn8’s southwire wire strippers giveaway?
Got the cutting board all but done today. Put a first coat of oil on. I eased over the edges with sandpaper. I went back and forth using a round over or chamfer bit but liked the eased edge better. Terrible lighting where I put the oil on. I’ll get a better pic later. [External image (uploads.tapatalk-cdn.com), not copied][External image (uploads.tapatalk-cdn.com), not copied]
rrich1 wrote:
Yes! I always love seeing the crew win. The crew has been knocking it out of the park recently
ya. lots of us have been winning. tony landin just won the tool pig milwaukee saw which was awesome!
Looks good there, i was working on making some end grain cutting boards but got way sidetracked with quite a few things here and there and have forgot about it. I want to pick it back up in the winter..
3 hours ago, KnarlyCarl said:Looks good there, i was working on making some end grain cutting boards but got way sidetracked with quite a few things here and there and have forgot about it. I want to pick it back up in the winter..
Do you have a drum sander? how do you plan to flatten the cutting board?
rrich1 wrote:
On 7/15/2017 at 10:02 PM, rrich1 said:Do you have a drum sander? how do you plan to flatten the cutting board?
Is that what you used? Do they work good? I have always wondered but have never had the chance to try one.. I would want to use a thickness planer for flattening it, then little sanding with random orbital.. but always interested in new ways the try things.
Jscott wrote:
59 minutes ago, Jscott said:Is that what you used? Do they work good? I have always wondered but have never had the chance to try one.. I would want to use a thickness planer for flattening it, then little sanding with random orbital.. but always interested in new ways the try things.
Mine is not an end grain cutting board so I used my planer. I used my orbital sander and a little hand sanding it called it a day.
I made a practice one and ran it through my planer with sacrificial boards out the front and back ends to prevent sniping, and made it narrow enough to fit through the planer. It worked really well. Then i’ll run a ROS on it
rrich1 wrote:
11 hours ago, rrich1 said:Mine is not an end grain cutting board so I used my planer. I used my orbital sander and a little hand sanding it called it a day.
Ic I would prob still use the same method never really considered the end grain needing to be done differently.
face board versus end grain boards…
end grain boards will self heal better suited for cutting
face gran boards will cut grain and will stay cut
face boards are more suitable for less cutting and more serving.’
On 7/22/2017 at 10:06 AM, KnarlyCarl said:I made a practice one and ran it through my planer with sacrificial boards out the front and back ends to prevent sniping, and made it narrow enough to fit through the planer. It worked really well. Then i’ll run a ROS on it
Ive seen MTM wood? on youtube do that same process. seems to work well. would like to see what you come up with later.
Jscott wrote:
On 7/22/2017 at 11:23 AM, Jscott said:Ic I would prob still use the same method never really considered the end grain needing to be done differently.
I had an acquaintance run an end grain board through a planer and the entire board exploded. I’m not sure if he tried to take too much off in a single pass or there was some weakness in the glue up, but to hear him tell the story it was impressive and terrifying all at once. I don’t know what the state of the planer was after the event, but I don’t know that I’d like to repeat his experiment.
khariV wrote:
2 hours ago, khariV said:I had an acquaintance run an end grain board through a planer and the entire board exploded. I’m not sure if he tried to take too much off in a single pass or there was some weakness in the glue up, but to hear him tell the story it was impressive and terrifying all at once. I don’t know what the state of the planer was after the event, but I don’t know that I’d like to repeat his experiment.
Wow sounds like something was off that’s crazy.. I’ve seen it done with no problem but never made a end grain one myself.. definitely something to pay attention to.. that would be a exciting day in the work shop lol
Found this post on TWW about end-grain planing. Take it for what it’s worth.
http://www.thewoodwhisperer.com/articles/end-grain-through-the-planer/
khariV wrote:
8 minutes ago, khariV said:Found this post on TWW about end-grain planing. Take it for what it’s worth.
That is a good article. looks like I will be stepping my hand plane game up before I start with end grain cutting boards lol.. thickness planers are to expensive to risk breaking it. And I just don’t see how I could fit a drum sander in my work shop
I have a few more cutting boards in glue up.bthe second one will be cut and flipped as well. These are not technically end grain boards. They are still edge grain. What are the chances they blow up on me in the planer? There is a festival this coming weekend and my neighbor has a booth. They said I could put some items in to see if they sell. I have never done this before but plan to make a few more boards and crosses as well to see if they sell. If not no big deal. It would be nice to get some money back from all the purchases. [External image (uploads.tapatalk-cdn.com), not copied][External image (uploads.tapatalk-cdn.com), not copied]
2 coats of mineral oil can really make a difference. Second pic is just cleaned with a little mineral spirits. Need to start oiling it today. [External image (uploads.tapatalk-cdn.com), not copied][External image (uploads.tapatalk-cdn.com), not copied]
That is absolutely awesome. Very cool.
Nice job saw this on instagram keep em coming bro!
Nice job man. Those turned out great.
Thanks guys. My only hesitation right now is realizing it is an all end grain glue up. I believe it will hold fine but would would feel more comfortable if there was face or edge grain glue ups somewhere.
Great job Rich! Worst case scenario, the glue up fails in a couple places and you learn something new. The best way to learn is to make mistakes…well except for shop safety or birth control.
Few more in clamps right now. These are a little more simple. [External image (uploads.tapatalk-cdn.com), not copied][External image (uploads.tapatalk-cdn.com), not copied]
The top board in the previous post didn’t pan out. The padauk skewed on me and wouldn’t have been thick enough in the end if I planned it down. I cut the padauk out and saved the pieces to do it again. I got the other one done and first coat of oil on. [External image (uploads.tapatalk-cdn.com), not copied]
okpermanent wrote:
On 11/17/2024 at 1:51 PM, okpermanent said:my old board is toast. and its time for a new cutting board. the idea of chopping and slicing on stainless or granite counter tops makes me shiver. so whats new in cutting boards. i was thinking of getting a poly board. but Im not really sure what to look for. my last board was some very hard knot wood oak i got at some craft show. thanks
Are you willing to make your own? For the most basic of cutting boards, you don’t even really need tools. A piece of cedar to your desired size, some food safe finish, and maybe a piece of sandpaper to cleanup the board to your liking is all you need. If you got a router maybe add a juice groove or finger hold if you want but not required. Cedar is naturally resistant to moisture so it would be a good extra insurance in addition to the food safe finish. Any wood would work if you have food safe finish on it.
