DEWALT Protable Hand Planer dust collection bag?????????
Blake BarnesMember since Mar 2014
I have a DEWALT Portable Hand Planer (D26676) and I can’t seem to find a dust collection bag that fits the this tool. It’s not just a regular circle so I can’t just use some adapter that would fit it. Does anyone have a solution to this?
Plug a vac in if you need too. Thus far I’ve just used it outside of my projects and let er blow.
Hugh Jass wrote:
That’s what I was thinking I might have to do; and just tape it or something.
Nice name by the way haha.
sorry, assumed it was the cordless planer…
Yea me too, that’s not going to work so well.
Maybe take a toilet paper core and zip tie it to the irregular side and then find a compatible adapter that fits the diameter for the vac side.
This at least will give you the flexibility you need while being able to adjust to the shapes you need.
what about rockier? they have those flexible fittings and and adapters
That’s a good idea! I’ll have to let you guys know what I do and post it on here.
Yeah I see one of those on there that MIGHT fit. I’ll see what I can do and then post it on here.
Turner85Member since Jun 2015
Dont bother with the bag even for the cordless version. Anytime i use it the chippings just clog up inside the plane and come back out where the blades are giving you a bad finish. I never got a blockage without the bag or when connected to a vac
I have to say the cordless throws chips like a champ though. Turn a yard into a field of sawdust in 10min flat.
I usually don’t bother with the bag in my Bosch and just make it snow in the garage
walteroMember since Feb 2019
 DEWALT:1- 800-433-9258  Will sell you one. Item:  Dewalt ADAPTOR 5140090-45
Hope this helps.
Here is much cheaper, if they have one.
https://www.mmtoolparts.com/store/checkout/cart/
MrNiceGuy3Member since Sep 2021
What about going to the local hardware store and getting a rubber fitting and using a hose clamp to attach it to the planer. That’s what I’ve done. About to try it now. Well I already had the fitting tho but came from local shop
Looks terrible but works amazing 🤩
