X-Carve projects
tugnut1Member since Jan 2016
I bought some really cool 2 inch thick wood recently that will make perfect cutting boards and other projects.  Last night, I made two Michigan Lower Peninsula cutting boards.  One was made from nearly 2 inch thick Walnut with the grain going West to East and another one out of Spalted Maple that started off close to 2 inches in thickness, but got run through the drum sander until I was happy which ended up being about 1.25″ thick.
I am also working on a Michigan State Spartan piece for an old boss of mine that is retiring soon.
How long did it take to cut through the 2″ thick wood? Whenever I see someone doing something with an X-Carve it’s usually less than a half inch of material.
What size router and what type of router bit are you using on the thick stuff?
I cut a little less than half way through on the xcarve, then cut the rest of the way with the bandsaw. I can cut close to an inch with this unit.
I’m using the dewalt palm router with a straight upcut bit.
