Custom knife
Made this knife out of an old saw blade and some flat stock and copper pieces. Cool history about those flat bar and thick copper the bar is for a power pole and the pole has since rotted away and also the copper is the grounding wire on power poles. I wanted to kind of base it off of Rambo knife and I am pretty happy with it. I sharpied the shape on the saw blade and cut it out with my cordless makita grinder and used a flap wheel to get it so shinny it probably took 3-4 hours and I sprayed a clear coat on it . I kept trying to decide on handles and tryed this one and love it . also left a tooth on the back as a window breaker.
dude thats awesome
1 hour ago, JimboS1ice said:
dude thats awesome
Thanks man ?
does it throw well?
Jronman wrote:
Just now, Jronman said:
does it throw well?
Idk I am guessing ?
I can’t remember if Rambo ever threw his knife at anybody. I remember he had a bow with explosive arrows.
I think he did but been awhile since I have seen it . I do remember the bow with explosive arrows. Also his m60 I think it was in the first rambo
CATERPILLAR wrote:
Rambo is a good quality action movie
Jronman wrote:
Yes love them ?
What method did you use for sharpening the blade?
Theultimatehic wrote:
Flap wheel then fine grit sand paper
That’s really neat Trevor! Never would have thought about making a knife from a saw blade…did you laminate layers together for thickness?
Hugh Jass wrote:
Thanks man ? no I used two pieces of bar stock and put the blade in between
I’m surprised the blade is rigid enough at single thickness. Must be one hell of a saw blade to be thick enough to keep it from being too flexible.
Hugh Jass wrote:
The saw blade thickness is about 1/8 its an older blade also
supersodaMember since Jun 2017
Stunning work you got there.
Forged in fire anyone?
“Nothing is Over” !!!!!!!!! (The only Rambo quote I remember)
Dude . That came out excellent .. Great Job !!!
supersoda wrote:
Thank you man
Thank you so much man ??
jbismuth18Member since Nov 2019
Impressive work.
