I am having a co worker who happens to be an electrician come over and hook up a 240v garage heater for me. I originally wanted to put it in the corner near the circuit breaker and my workbench to keep from running a huge line of wire. I just hung it up and now am not sure. I have it on the high ceiling setting right now if I keep it there I will move the wood storage to someplace else. Would it being on the other end of the garage be better? It says a minimum of 8 inches from a wall and it is at least 11 from the back and more from the left wall.
Nice Rich, I’m researching something for my basement shop now.
I got this one at Menard’s for $200. Originally over $300. 7500 watt I believe. Dont mind the mess. I have literally been throwing just places while trying to finish the bathroom. I started cleaning up after the pic. Not even going to show the other direction lol.
Let us know how it works out once it’s all wired up. I spent way too much time last week looking into garage heaters, so I’m definitely interested in hearing how this ends up.
my buddy went through this as well however he has 12 foot ceilings so he also installed a 72″ ceiling fan low profile style to push the air down made a world of a difference, another buddy put his heat in the far corner and ran a small 12″ fan blowing against the opposite wall to keep air moving both set ups work great we live in winter weather near 40- and you can work in either shop wth just a T-shirt
Will do. It is going in at 0830 tomorrow. Of course it is in the 40s this week. I could have used it 2 weeks ago when it was in the negatives!
I’m hoping with the placement of the fan it will allow me to keep the heat lower and on less frequently due to the proximity of where I will be to it.
Heater is in and running. Works well. I need to insulate my ceiling to make use of the running heater.
rrich1 wrote:
8 hours ago, rrich1 said:Heater is in and running. Works well. I need to insulate my ceiling to make use of the running heater.
Nice !! Stay warm
Hah, no kidding! That’s what made me start looking – trying to finish Christmas presents in the garage while it was -10 outside. Miserable experience! Hopefully the heater works out well for you.
Stay warm!
Even though electric is easier to install I couldn’t afford it my garage with Michigan electric rates. I think I would go with a pellet stove
my neighbor only has a 20′ x 20′ shop/garage he insulated it well and runs a propane heater right out of a scrapped camper, 100LBs tank lasts 2 seasons and is quite nice in there to work very cheap heat…….mind you he is a weekend warrior so it is not on full time…..
Wood stove or propane would have been good options but a few reasons why I didn’t go with them. 1. No floor or wall space to put them. 2. I have two kids 4 and under. They know better and I know wouldn’t have messed with it but this way it is up and out of the way. I don’t plan to keep the heat up by any means. It is meant to keep me from freezing in there and take the edge off. Probably be the highest around 50 degrees.
Well this sounds familiar! My dads coworker, who also just so happens to be an electrician is running a couple of lines into our garage, one of which is for a heater!
Awesome. What did you get. I also got an outlet installed that is wired for 220 but reduced for 110 use right now. I’ll I will have to do is change the outlet and put in a 220 breaker and I’m all set. You know just in case I get some better tools in the future [emoji106] [emoji16]
rrich1 wrote:
6 minutes ago, rrich1 said:
Awesome. What did you get. I also got an outlet installed that is wired for 220 but reduced for 110 use right now. I’ll I will have to do is change the outlet and put in a 220 breaker and I’m all set. You know just in case I get some better tools in the future emoji106.pngemoji16.png
I know exactly what you mean. Were having 3 lines brought in. 1 for a set of outlets, 1 for the heater and 1 for a main outlet that my compressor will be plugged into. Right now, there is a 220 line in the garage that was disconnected by the previous owner. So if we can find the other end of that line we will hook it back up for, like you said, if I ever get better tools! A friend of my dad actually gave this unit it to us so Im not sure of the brand but it is a 5000W which should be sufficient for my 19’x19′ garage . And like you said, we only want to get the chill out so when it is 0 degrees outside, 50 degrees feels pretty warm!
DaveJr. wrote:
4 hours ago, DaveJr. said:I know exactly what you mean. Were having 3 lines brought in. 1 for a set of outlets, 1 for the heater and 1 for a main outlet that my compressor will be plugged into. Right now, there is a 220 line in the garage that was disconnected by the previous owner. So if we can find the other end of that line we will hook it back up for, like you said, if I ever get better tools! A friend of my dad actually gave this unit it to us so Im not sure of the brand but it is a 5000W which should be sufficient for my 19’x19′ garage . And like you said, we only want to get the chill out so when it is 0 degrees outside, 50 degrees feels pretty warm!
Sometimes taking the chil out of the air is all you need
I would like one of those in my garage that blows cold air. It was about 80 here today.
rfwjr wrote:
5 minutes ago, rfwjr said:I would like one of those in my garage that blows cold air. It was about 80 here today.
Must be rough!
DaveJr. wrote:
10 hours ago, DaveJr. said:Must be rough!
Cold front coming tonight ….should hit the 40’s at my house for a low …….
that could be rough ……????
Foneguy wrote:
1 hour ago, Foneguy said:Cold front coming tonight ….should hit the 40’s at my house for a low …….
I think my shower was that cold this monring 40….lol
Foneguy wrote:
3 hours ago, Foneguy said:Cold front coming tonight ….should hit the 40’s at my house for a low …….
The cold front came through last night. We are in the 60’s today, was worried I might have to wear long sleeves.
What they hell 60’s that’s shorts weather in Michigan!! Hell people break shorts out even sooner in the spring here.
2 hours ago, DR99 said:What they hell 60’s that’s shorts weather in Michigan!! Hell people break shorts out even sooner in the spring here.
LOL after our sub zero freeze 35 felt like short weather the other day
It got up to high 50’s on Monday only thing that sucked was it was rainy and ugly out 🙁
rfwjr wrote:
and I want the air brought up to around 50 degrees to work comfortably. LOL
rrich1 wrote:
1 hour ago, rrich1 said:and I want the air brought up to around 50 degrees to work comfortably. LOL
Brought UP to 50 degrees ?????
Foneguy wrote:
9 minutes ago, Foneguy said:Brought UP to 50 degrees ?????
Illinois. yup. it gets cold in the garage. lol
rrich1 wrote:
15 minutes ago, rrich1 said:Illinois. yup. it gets cold in the garage. lol
Cold ???? Now I’m confused
Sometimes cold is an improvement ha ha
Yep. It was 52º where I am in Maryland today. It was a big improvement over yesterday’s 29º. Yesterday I was too cold to do anything outside. Today I was outside dealing with a few projects in a t-shirt.
I have been using FUH54 model by Fahrenheat for a long period of time. I have a medium size garage and it has been heating very well. There are also some other great options available for electric fan heater. I would recommend you to read the best electric garage heaters guide by ”’Garageaxs”’
