They have multiple similar products at Canadian Tire, which is the only retailer I’ve seen it at around these parts. Hopefully they are good quality.
Yeah. All those products are showing up in Home Depot now. They’re spread out among stores. Some stores have the smaller 1400amp units and some have the two battery bench charger.
The wheeled charger is $299
This jump box is $249
The smaller jump box is $149
And the bench charger is $99
They are here now ? as in that pic is from a local hd ? where do i go ?
Yes. They’re in HD. at least they are in Houston.
They’re still inactive in the system. So you have to hunt them down in top stock.
Automotive dept ?
I’m going to get the bench charger tomorrow. It’s not at a store near me.
Oh damn i want that. dont need it but want it…im gonna hunt 2mro after work….thanks for the heads up….tough to find things here on the cape
I read the specs on it at Canadian tire….i get it charges using usb..and jump starts a car battery…and has ac outlets…do you plug this in to charge ..it.. ? how long does it take to charge this ? how long can i power a tool off this ? . …
Initial impressions are that this thing is very well built. I’m doing the initial charge on it now. The compressor has a digital setting. You choose the PSI, start it and it fills until the PSI reaches the setting and shuts off. Very nice feature.
Has USB chargers, lights on the back, detachable leads. The leads are short. VERY short. So the jump box needs to sit on top of the battery basically. But, I imagine an option to buy longer leads since they are detachable quick connect.
It also has a watt meter for the 110v outlets to tell you how many watts draw you have.
It was about 75% charged so I can’t say for sure. You plug an extension cord into the back. It also has a cigarette light option to charge from the vehicle once you jump started it. This thing is super heavy duty. I can see this being a very useful piece of equipment.
Manual says 40 hours to fully charge via 110v charging method.
Thats cool…thanks…between my flexvolt dcb1800 and this …ill be all set…. ( well i always want more but…)…..
Here’s the smaller jump box.
Saw one of them at a south side Chicago store
Which one did you see?
I’m curious if they’re doing the same thing as around here. Only certain stores are getting certain models while other stores are getting other models.
So I’m going on 3 hours and it’s still topping off the charge.
It’s interesting how these are made by Baccus Global which makes the currently stocked CAT, Stanley and B&D automotive chargers and jump boxes. Seems like a conflict within Home Depot.
What a great find! Have not seen these in Michigan yet. I have been looking for a jump box. Now I will look for these ones. Thanks Ricky!
It was either the smaller one or the one that looks like the radio
Dude do you need my address to send me all that?
I was looking to add one to my Christmas list as my 500amp one just isn’t cutting it.
I saw someone in Canada posted these so I decided to wait. Thankfully, I found this in the top stock today.
It seems to be very well built. The way I am looking at it currently is that Baccus Global has been making the Stanley and B&D units for quite sometime so the quality must be there and the feedback must be positive. Stanley B&D is the parent company for DeWalt so if there were issues, they wouldn’t let Baccus put the DeWalt name in the product. It also has the highest amps and watt ratings of any unit I can find. So it boils work on my diesel.
Picked up the bench charger last night. I have initial mixed thoughts. It’s very lightweight, light gauge housing. Only comes with one set of leads. The second set has to be purchased separately to take advantage of the dual charge capabilities. The features are fantastic if they work as advertised. I’m going to look for some old batteries to test out. My diesel truck is in the body shop so I can’t give it a good testing this week. Once I get my truck back, I’m going to do a little testing on both units to see.
The units are all built by the same company and the other units that are branded CAT, Stanley and B&D all have positive reviews.
I just want one…or …maybe both..:)…appreciate your info…
Man I have a old Husky jump box that I bought probably 10 years ago that’s about to bite the dust, and the number of times that little box has saved my ass and those I’ve helped with it, it’s paid for it’s self a hundred times over. The compressor died last year and she’s not holding a charge like she used too (but damn this thing is old so I’m impressed it works at all!)
I’ll be getting one of these soon. That digital pump is TITS.
looks like a radio. does it have radio functionality?
Only if you plug a radio into it.
Bremon wrote:
34 minutes ago, Bremon said:Only if you plug a radio into it.
or leave it unplugged and just sing!
1 hour ago, comp56 said:or leave it unplugged and just sing!
The Sawzall Quartet
Lol this has been the news this hour on TIA fm with your host Bremon!
