Preferred ratchets?
I’ll be the first to admit I have a thing for ratchets. I probably have 9 or 10 in my roller box and when I die my boys will be saying “why the hell did dad have a whole drawer full of ratchets?” They are by far my favorite hand tool. I have a set of 72 tooth Danaher era Kobalt’s, Williams era Kobalt’s, vintage Thorsen’s, and a WWII era Plomb. However, my go to ratchets are my 24 tooth Proto pear heads. I’ve got a full standard length set as well as a 16″ 1/2 model and I love them. They’re built like little chrome tanks and I never feel the need to use a breaker bar. I don’t own a dual 80 Snap-on…yet, but it’s on my list. What do you guys prefer and why?
I like Snap-ons for fine work and S-K for when the going gets greasy. Snap-on for the fit and finish, they feel good in the hand. S-K because the knurled handles are easy to hold onto even when everthing is absolutely covered in grease.
I have to admit that this is not always the case, as I often end up grabing whatever ratchet is close at hand. I have a Belzer in the tool box on my bench that sees fairly frequent use, along with a few vintage Craftsmans that I have scattered about and a Stanley set that ends up on some jobsites when they might end up walking off.
Speaking of ratchets, does anyone have an opinion on Wera’s offering? I have been dreaming of a one of their Zyklop swivel heads
[External image (www-us.wera.de), not copied]
Nice looking ratchet, though I’m not sure how I’d like the molded grip. As a rule, I’m not super crazy about flex/swivel ratchets. I have them, they are indispensable in certain situations, but I do not like to use them when it isn’t absolutely essential. I’ve never been real big on molded cushion grips on anything though, especially pliers and adjustable wrenches. I’m kind of a purist when it comes to hand tools.
I agree 100% about the knurled grips. That’s what I love about the Proto’s, you can tear into a rear suspension, under carriage, tractor, or whatever and no matter how nasty and stubborn it gets your covered. The tough 24T gear and knurled grip make it a real war horse, the old school Thorson 77’s are the save way. Take the leaf spring out of an F-350 with any of those Kobalt’s and your ass is headed back to Lowe’s.
I don’t care for the over mold much either, my main gripe is that they just about always end up getting shewed up and they hold grease really well, not to mention what happens when you get them near any srtong solvents. I think it is impossible to find a swivel head without one these day though. Even Snap-on went that way. I really like the old version with the black plastic handle like they used to put on their screwdrivers. I find swivel heads to be very handy for assembly work. start off like a screwdriver and swing it down to finish tightening it up.
My Kobalt flex heads have a solid metal handle, but they don’t pivot exactly like this one.
The swivel heads are better for me because they can be used like a screwdriver unlike the plain flex heads which don’t work that way. Works best in 1/4″ drive, although 3/8″ drive makes a passable screwdriver like tool, 1/2″ is kind of clumsy but still can be done. With the bigger tools I don’t always feel comfortable really bearing down on this style of tool but for lighter work I do like them.
While I didn’t look to hard, I didn’t see a tooth count on this ratchet. However, with a 5 degree return angle I’m guessing it’s fairly high. I prefer a 72 tooth count for 1/4 drive and I’m assuming that’s what this is. I like a smaller tooth count like 24 for 1/2 models and for 3/8 I think 60 is probably ideal though a 72 is still a bit handier.
All this talk about ratchets made me go and order one. I dropped $40 on a Proto 4757 1/4 flex head. I went ahead and spent an extra $12 on a 4757 6″ flex extension. I’ve got a 72 tooth Danaher era Kobalt but it’s gotten a little rough in the gear and I’ve got a 24T Proto pear head but I prefer the smoothness of a 72T for 95% of 1/4 applications. I’m not crazy about flex heads but 1/4 was the only size I didn’t have one in and in my opinion it’s probably the most practical size for one so I guess it’s problem solved. Guess I can go to Lowe’s and swap out my old Kobalt clunker for a new Kobalt clunker.
Looks like a nice couple of tools, I also find myself lacking any 1/4″ flex heads. Have you ever tried a 1/4″ swivel head? I really like the ones I have used, and this is the ideal size for this style of drive.
For 1/4″ fine tooth is really good as it is not really going to be exposed to any real high torque applications. I tend to strip out any of the larger sizes with fine teeth unless I take the time to put them aside when the going gets tough. I tend not to keep mine real handy for this reason. I have had Snap-on rebuild a a few of my ratchets and they have been really good about it. How is Proto on getting warranty repairs? I have never tried to get any repaired.
Never used a swivel head ratchet. I can see the advantage in certain situations, I guess I just never had the right occasion to purchase one. As far as Proto warranty goes my limited experience with it has been positive. When I got my 16″ 1/2 model as a hand me down from my dad it was missing a spring. He got it from work so God only knows how it came about getting lost. Regardless, I called Proto, told them it was sticking and 4 days later I had a rebuild kit in the mail. I filed for a warranty exchange on a pair of bent nose pliers after I broke about 1/4 of the tip off. I mailed the broken pair in and got a new pair in the mail with a total turnaround of about 8 days. A lot of people go swap them out at Grainger but I’d just as soon mail it in as I would drive an hour to Grainger and back. I like Proto stuff a lot. You get a high quality tool without having to run down a truck or pay for the cost of keeping that truck running. The truck setup works fine for people who work places that are on the route, but for me it’s just a hassle.
Got a call from tool source today. Apparently the ratchet I purchased is a discontinued model. The new model has a slightly different head design that incorporates a thumb wheel which I suppose is a good thing. It cost an additional $11 making it a $50 1/4 ratchet. I wouldn’t have cared to pay the additional money as I know the tool is top quality but lucky for me they agreed to let me have for the price I paid for the old one. Can’t complain about that.
michaeljjMember since Oct 2012
24-tooth proto and snap-ons are my favorite and i have owned and worked with them through decades. I am looking forward to expand my collection, and looking to have a few vendors in sight to help me out.
dewalt 14.4 battery
Here is the updated 4757 I’m getting instead of the original posted model
[External image (www.nkbaxter.com), not copied]
Is that a female torx fitting inline and opposed to the male 1/4″ drive side?
I believe that torx screw is what’s holding it together. Can’t swear to it though, it hasn’t arrived yet : (
ricksterMember since Sep 2012
SK Rotohead, one of my favorites! Only in 3/8 dr though..
[External image (ecx.images-amazon.com), not copied]
http://www.amazon.com/SK-Hand-3870-Professional-Ratchet/dp/B00061SNCU
I have a lot of respect for SK. A 100% American product line is a rare thing anymore.
After a month on back order the J4757F came today. Very happy with it on initial impression. What appears to be a thumb wheel is simply for reversing directions and the Torx screw merely holds the ratchet together. Very smooth operation. The flex head does not have positive stop capability. I guess it’s a matter of preference. It doesn’t bother me at all on a ¼” model but I don’t think I’d care for a ⅜” or ½” without a positive stop function on the head.
Few of us in chat were talking about starting a thread to show off your ratchet collection, don’t matter the brand eventually ill get a post of my HF ratchets so don’t be ashamed, but here is a shot of my Proto collection, I love these things, mostly i reach for the quick release. The chrome ratchets are a 45 tooth spearhead quick release.  The black are a round head, 72 tooth Facom design proto, these have a 5 degree swing arc, the chrome ones have an 8 degree.  Great solid ratchets, I’ve lubed them all with superlube!!
Kato wrote:
8 minutes ago, Kato said:
Okey dokey…
Whole family, except for the two pass-thru ratchets. Gonna probably give those two some time on the new carbon fiber background…
[External image (farm8.staticflickr.com), not copied]
Ratchets 002 by Edward Durbin, on Flickr
And a shot of the smallest ratchets I own…
[External image (farm2.staticflickr.com), not copied]
Tiny Ratchets by Edward Durbin, on Flickr
that a new ratcheting sharpie?
T75RMember since Jan 2016
That sharpie is hot
KatoMember since Jan 2014
Sharpie is there for size reference…
Nice collection fellas! I’ll try and get a pic of mine at home hopefully 2nite and take a pic of my others at the shop also
Here are the ratchets that live in my toolbox. My most used ratchets are the Carlyle ones. The 3/8 snap on ratchet is the newest one.
NicholasShetley wrote:
How are the carlyles in comparison to the Pittsburghs in price and functionality? Is that cart your new one?
I’ll see if I can’t get a group photo of mine. I think I have 16 now.
I have that composite HF ratchet, you like it?
Stercorarius wrote:
The carlyles are some of the best ones I’ve used. The long 3/8 was about $45 if I remember right. The roto ratchet was 60 or so I think. I Like them way better than the Pittsburgh ratchets.  They don’t flex as much and they ratchet much smoother. They are incredibly strong too. The 100 tooth is on almost all of the trucks and I saw it first with the Carlyle name on it. I’m not sure if they were the first ones to use it though. It is just the bottom portion of my toolbox. I havent bought a cart yet
Here are mine:
I keep wanting to get a couple of palm ratchets but never do. Sooner or later I gotta get one or two, they look way too handy to not be using one
Kato wrote:
He accepted my $8 offer a while back, the knurling isn’t great but the action is smooth.
http://www.ebay.com/itm/SK-45172-3-8-inch-thumb-drive-ratchet-/191856837110
I don’t really recommend the Kobalts but I got those in a couple of sets built around that palm ratchet for like $6. The Kobalt does 1/4″ sockets and 1/4″ hex bits, it has a 1/4″ extension that can be inserted in the side to make it into a handled ratchet. Also the 1/4″ female side of the extension accepts 1/4″ hex…but because it’s hexagonal it doesn’t stay on the male 1/4″ square very well because the ball doesn’t lock on. I have one set in the car and one at work, never really used either set but I can see how the set can be handy…I just have better options at work and haven’t needed it in the car.
Paid the same for that Sk, its not a bad little ratchet, like Bmack said the knurling sucks but the ratchet mechanism is nice, needs to be lubed but beware its a tricky little fella.
That gear wrench is might sexy
Yup…it is.
Actually I have been looking at a Gearwrench pass-thru set recently, you’re not helping my budget at all by posting that picture.
I have been Impressed with the stuff I have bought from GearWrench. It sucks its not make in the USA but the quality is nice and so is the price point of their tools
Onviously I’m a big fan of Gearwrench, if I were a rich man I’d have my garage filled with their stuff…
Well, this is my favorite. Have plenty of crap that isn’t worth a pic, haha.
DaveJr.Member since Nov 2015
Here’s mine. Plus 2 1/2 inch breaker bars (one in my car and 1 in my dads).
phffterMember since Mar 2016
hmmmmmmmmmm………….. dont have an up to date pic.
i’ll will, if you guys desire.
i just have this pic of rats i put driver handles on. sometimes, a hard handle to pull on is hard on the paws.
[External image (www.forbbodiesonly.com), not copied]
Dude that’s awesome!
Congrats hombre you got me to order in the long flex head Carlyle, it was about $60 while that 100 tooth was $100 so I will pass on it untill I can get a good deal on it.
Stercorarius wrote:
Glad to see I made you give in. Let us know how you like it. I need to take mine apart and lube it. I can post pictures of it if you want. The ratcheting mechanism should be the same.
gathered them together. had to id some with tape, so they’d go back where they belong. i forgot my 1” set at the job site, along with a few others. torque wrenches and ratcheting torque adapters, refrigeration ratchet (that’s another thread), and prehistoric type not included.
listed by size, 1/4 thru 3/4. no harbor fright. 1 gearwrench.
[External image (i448.photobucket.com), not copied]
