New youtuber.
I recently started watching a woodworking youtuber I hadn’t seen before and what I thought was interesting about this particular youtuber is he invents new tools. For example, He has designed some prototypes for a saw blade dado setup to make drawer creation easier and faster. I might even try it after it comes out on the market. He is still working with a partner to create a final design. He also has built some prototypes for a 4 way parallel clamp. It not only provides horizontal pressure but vertical pressure as well. One of his tests read a little over 200 lbs of vertical pressure. I suggest subscribing to his videos. If you arent interested in subscribing at least check him out.  Heres the link to his channel https://www.youtube.com/channel/UCYJ6JJ7Q938Fls5He8zYRFA
