Initial Thoughts on Ridgid R4512 Table Saw
ok so we know it is not a $3000 cabinet saw but I will say this…. it sure presents itself as trying to be one.
I bought this saw to cut hardwood without spending the high price of the full blown saws
my first thoughts are very impressive, sure it took me about an hour and a half to dial everything in but I’m happy I did
as the results are great. I did not even install the supplied 60 tooth blade, I will keep it for just ripping building material if need be.
here is a shot of Paduak an African hardwood that will give the best of saws a true test from its hardness
as you can see I can cut 0.0500 (less than a 1/16th of an inch) thick strips like butter with a pre-sanded finish using a 90T Diablo UFF blade
Great to see Comp. Hard to believe you can get those kind of cuts from a saw at that price point. You said it took an hour and a half to get dialed in. Was that because you are a perfectionist, or is it a bit cumbersome to adjust?
kruton wrote:
yes it was me being a perfectionist, the entire assembly was very easy by myself the only thing I needed help with was getting the saw body out of the box as you assemble it upside down and then I needed a hand to flip it over. (didn’t want to break up the box just in case I had to return it) most of the time was spent fine tuning everything waxing it up making sure everything was true with the 2 x 5 cut tests ….truthfully it was pretty good out of the box I just thought if I can get it closer why not……
Nothing wrong with that, I’ve seen enough of your work on here and how nice it is that I assumed it was just you wanting it to be as precise as possible. You are really making me want one of these Comp.
kruton wrote:
if you are looking for a full body stationary type saw I don’t think you can buy a better saw for under $600 granted I put a $100 blade on it which is worth every penny as I know for a fact it won’t have crap used nail filled wood going through it…..that is what the original blade is for……lol oh and saved about $60 by making my own Zero clearance insert….
What did the saw run you?
In Canada it was on sale for $599 plus the $97 for blade
here is some Walnut, Hard Maple…. if someone says these saws don’t cut straight I will beg to differ….
Tx_woodworkerMember since Oct 2016
Well Im glad you’ve had better results with your ridgid table saw. Looks great. I had one a year ago and the rear cast trunnion was out of spec every time I beveled the blade and brought it back to 0 the rear trunnion would shift causing the blade to heal badly in the rear. Ultimately I sold it.
Tx_woodworker wrote:
yes they apparently fixed this issue by beefing up the trunnion design you can tell if  there is a Roman numeral “II” stamped on trunnions. can’t say I have pushed 1000’s of board feet through the saw  with bevel cuts and 0 cuts but what I have cut so far has been good.
I’m looking at the delta 5000 series with the biesemeyer fence.
Im a huge delta/porter cable/rockwell owner.
So with what your saying, would a 2015/2016 ridgid saw have the upgraded trunnions?
I’m not sure exactly but the newest the better obviously……
rrich1Member since Jun 2015
If you are looking for something a little cheaper than the 5000 series. I bought the 36-725 delta saw from lowes and am very happy with it. buy online with a 10% off coupon code to save some money. Or if your local HD accepts harbor freight coupons the Ridgid saw would be a killer deal with a 20% coupon.
glad you like the saw comp. My HD didnt have any set up when I looked for my table saw. The delta and ridgid were my top 2. which blade did you go with? I run the frued industrial combo 50 tooth blade. Just purchased the freud industrial thin kerf 24 tooth rip cut blade and it is outstanding. less than $40 for it
I am happy with it and getting it on sale for $599 compared to $749 (Canada prices are so much more some times) I looked at the Delta as well from lowes for $749 but they wouldn’t budge on price to match HD
I went with the 90 tooth UFF diablo blade as I cut a lot of hardwoods and with this fine blade it is glue edge ready…..
ill check that blade out. i dont think I have heard of UFF before.
fine finish
I really looked at that saw and it clearly is a great machine. Like Rich it was between the Delta and the Ridgod and that Rodgid is a well thought out machine.
The other brand I would strongly look at is sawstop. Thats because I use one on a daily basis. Thats good to hear on the rigid table saw though. I have a 14″ bandsaw and drill press that work well.
oh I know there are far better saws out there but not in this price range …..
tugnut1Member since Jan 2016
I’ve had this saw for about 4 years now and just love it.  I totally agree that for the price, you can not beat it.  The only saw that I plan to replace it with is a sawstop cabinet saw, but that price is about 5 times as much.
