Zero Clearance Inserts….And Added Hacks***
So if you don’t know me by now I like my Zero Clearance Inserts for table saw or miter saws, I see RIDGID makes them for their table saws but they seem to be way over priced…….
So I made my own…with guards and riving knife and without….
RIDGID take Note:
I think mine looks better than yours…..
Looks great comp!
Dammit Comp you make everything look so epic 🙁 It makes me feel like less of a man 🙂
DR i agree ☝️ lol!
thanks guys….
Once again Comp=Awesomeness! A little surprised you didn’t paint it red though! [emoji6]
FRIGGIN Magician !!!
tugnut1Member since Jan 2016
That is amazing.  Looks better than theirs for sure.  I just made one for my miter saw out of Walnut, but it doesn’t look anywhere near as nice as yours.
I love how you always go the “extra-mile”, that insert is definitely an example of that.
Thank you guys…..
I also added a wood side to each side of the fence, I don’t know if it is old school or not but the aluminum rail just didn’t do it for me. So I took 1/2″ birch plywood and planed it clean both sides, added it to the fence…..sure I lose a bit of ripping length but I’m ok with that. another thing was not that it mattered but the indicator for both sides of the fence were now going to be out by the thickness of the added wood. So I fixed that by removing the measuring tape and moved it outwards accordingly to the proper place on both sides of the blade. I then covered the middle with silver vinyl so you couldn’t tell. Now regardless if I use the indicators or a tape measure they are lined up true with the added thickness of the fence….
ok I’m done now couldn’t just have bare wood…….. looked un-finished ……
That’s great Comp. I love how it looks like it came from the factory that way.
rrich1Member since Jun 2015
looks awesome!  good job. I need to make some inserts for my delta real bad
RIDGID take Note:
Gorgeous insert dude. Are you going to make another one for dadoes?
ChrisK wrote:
thanks dude yes and also 22.5 and 45
Nice! That’s really awesome work!
LarrySMember since Dec 2014
I like both !!
Nice !!!
Freaking awesome work.
rfwjrMember since Jul 2014
Looks Awesome Comp.
Fantastic !!!! ….. as usual ???
so I came across this floor switch I figured I have a shop vac connected to the table saw and instead of bending down under the side of the saw each time to turn shop vac on and off I tie wrapped it right to the table saw main power switch, now I can turn them both on in one easy motion plus I can turn off table saw and wait a second or two then turn off shop vac or vise versa….
I need to do that. I am horrible about turning on my shop vac for the table saw.
