I’ve opened my DCD925 battery the other day…it has 12 18650 cells. I guess it’s 2P6S.
Other tools use 5 cells in series instead of these 6.
Do you happen do know how many cells the other Dewalt lithium batteries use?
QuoteHow much is 18?
Legal.
As for the cells I have no idea.
the flexvolt has 3 rows of 5
18v nominal usually is 2 rows of 5
dewalt use 10 18650 series to get 18v
pancing wrote:
6 hours ago, pancing said:dewalt use 10 18650 series to get 18v
In many cases, it’s 5 in series (or ten total: two parallel banks of 5).
But in my battery, I can count 12 cells in total. Linked two by two in parallel, that means there are six in series!
Martini wrote:
3 minutes ago, Martini said:In many cases, it’s 5 in series (or ten total: two parallel banks of 5).
can you post the internal of the battery?
yeah that might be the xrp extended run time pack
It’s a DE9180.
It doesn’t mention XRP (might be older, goes on a Type 10 DCD925) but NANO technology.
Martini wrote:
4 minutes ago, Martini said:It’s a DE9180.
I’m not sure what that is then I’ve seen pictures on google about that battery but I only count 10 batteries 2 on each side 6 in the middle I’m not exactly sure where you’re getting the extra 2 from because 12 batteries would be 24V full charge and 21.6v nominal
pancing wrote:
1 hour ago, pancing said:I’m not exactly sure where you’re getting the extra 2 from
Martini wrote:
1 hour ago, Martini said:You will count 3 + 3 + 2 + 2 + 2
(The last 2 being between the two rows of 3)
ur gonna have to post a picture man because all the ones I see on google have 2+2 3+3
Martini wrote:
3 hours ago, Martini said:
That was the picture.
