Unmarketed feature for the new grinder?
I just read a post on facebook from someone who says they have the new grinder and found a feature that nobody is talking about. Apparently if you take the 4 screws out of the top head assembly, you can rotate it 90 degrees to change the angle of the blade.
I find this very interesting indeed! I do very little grinding and mostly cutting so I’ll be testing this out for sure, the improvement in ergonomics of grip would be substantial.
I think that works on almost every grinder or at least a lot of them.  Usually it opens up the gearcase though so it’s not something you want to do on a dusty jobsite (ie. the kind where you’re using a grinder)
jeffmcmillan wrote:
Huh, not something I’ve ever heard of…does the 20v do this too?
Hugh Jass wrote:
I recall the 18V dewalt did so the 20V should.
It’s not something that’s advertised, just inherent from the easiest way to assemble the gearhouse of an angle grinder.  I first discovered it by accident when I reassembled a Makita angle grinder the wrong way.
Interesting. Wish I had known this years ago, lol.
Hugh Jass wrote:
Look at the gearbox portion of any grinder you would like to change, measure the spacing between the bolts and see if they are evenly spaced. Remove all four rotate 1/4 turn and put bolts back in. I am not going to tell you that you can’t turn it one direction, you can learn that all on your own. You can eat all the grinding dust/ sparks you want if you insist it be on the side that throws it toward you instead of away…
Grumpy MSG wrote:
Or perhaps I’d rub both of my brain cells together and just use the guard…or maybe I won’t so I can eat debris, that sounds pretty good too.
