Dado with plunge router help
peroxwhygenMember since Apr 2016
How can I finish the cut no router table or table saw the block of wood must be there
What am I looking at?
Micro fence jig to make a straight line with a router. I am make a cabinet that goes underneath my workbench.
I’d disassemble the joint if it’s imperative to use the jig or else I would just make a new jig without attaching it to the router base so you can route into the corners. Kind of hard to give you an intelligent answer though without seeing exactly what your trying to do, can you draw something up or move the router and jig aside?
[External image (uploads.tapatalk-cdn.com), not copied] the groove is for the rod that will go into by table legs
Ahha I get it now!
I would move you fence to the outside of the frame, nothing will get in your way then.
Then adjust the guide fence to keep routing where you left off
Yup, what NotCarl says! You can disassemble the pocket joints too but he’s dead on that’d work excellent!
