Ridgid 18v Brushless Impact Driver Wobble
Archived from the Tools In Action forum (Ridgid). This thread is read-only.
TormundMember since Jun 2016
Just how much wobble is normal on a ridgid impact driver? I have the gen5x brushless and just recently took it out of the box.
Here’s some footage. Bit is around 2.5 in.
Ridgid 18v brushless impact driver gen5x 2.5 in. drill bit
Bosch 12v drill with the same bit side view
Ridgid 18v brushless hammer drill gen5x same drill bit from the rear slo mo
Bosch 12v drill rear view slo mo
Ridgid impact driver rear view slo mo running at top speed
That’s normal on any impact.  theres no chuck like on a drill to tighten the bits down. When I first bought an impact I actually had the same concern until I started using it. Once the bit starts drilling in wood it’ll run true
Check if there’s still wobble once you start a hole.  If there is then it’s a problem.
If it drills straight into wood then it should be fine
It wobbles when I drive a fastener. I’ll try to get footage of that. Thanks for the replies.
KencaliseMember since Sep 2020
Hi.
I just bought this kit(R96172), found out the impact driver shaft wobble. Then I used my old makita impact driver with the same bit. The makita doesn’t wobble. Is that mean I got a bad batch?
Thank you.
