it shouldn’t be hard at all. Just center punch where you want to drill and I would start with a smaller bit around an 1/8 or so and you should be fine.
Shit bit=hard to drill, halfway decent bit should go like butter.
Stercorarius wrote:
38 minutes ago, Stercorarius said:Shit bit=hard to drill, halfway decent bit should go like butter.
This. Good drill bits can be expensive but they are totally worth the $100-$150 /set entry price.
I also like to spray a little WD-40 on my bit before I drill through metal, there are better lubricants but it’s what I have plenty of and it works.
Yep. If you aren’t doing a ton you should just grab a $8 jobber bit instead of dumping over a hundred on a full index. For one or two holes the DeWalt gold and black oxide bits will work alright.
Yea if your drilling in steel regularly invest in some cobalt bits, but for occasional use your fine with middle of the road bits form major brands just don’t expect the but that you used to have a long life.
Also with steel keep the rpm’s slow it keeps the heat down.
Especially on sheet metal. Don’t push so hard that you leave a permanent dent. This can be a avoided by clamping a sacrificial block of wood on the back. Its the only way I’ll put any sheet metal under a drill press.
I like putting a wood block under metal when drilling, sometimes when the drill bit breaks through it will catch and can distort the metal or try to rip the drill out of your hand…block of wood behind it prevents that.
If they are small holes you can use a much larger drill bit to clean up the hole(if the metal is thick enough), otherwise you need countersink bits or a file and some patience. Basically with the drill bit you just want to take off the burr and make a tiny bevel(larger if you want to recess the fastener obviously), literally it takes about 1 second of trigger with little to no pressure on the hole. Careful with the drill bit, if it catches it will just make more work for you.
15 hours ago, BMack37 said:I like putting a wood block under metal when drilling, sometimes when the drill bit breaks through it will catch and can distort the metal or try to rip the drill out of your hand…block of wood behind it prevents that.
Great advice if your drill doesn’t have a safety handle!
that looks like plain ole structural steel to me,any decent bit will do that shit is soft.
I would buy good bit because it will be a lot easier
