Archived from the Tools In Action forum (WANTED). This thread is read-only.
I’m looking for a couple unwanted, non-working M12 tools. Pretty much any tool would work.
I literally cannot think of a single m12 tool in the entire company inventory that isn’t working and unwanted…. but I’ll keep you in mind
What do you have planned?
Yeah, I know it’s a long shot. I might end up buying a housing from the parts shop and using that.
I’m planning on making basically a 12v power supply for automotive accessories. My main want is to use a fuel pump as a fluid transfer pump b/c I know I won’t be spending the money on the Milwaukee one when it becomes available, I know that will be pricey.
I believe the old flashlight is your best bet. IIRC Someone on here used one for a clay pigeon thrower.
What do you want? With my luck, any tool I buy won’t be working…:rolleyes:
Stercorarius wrote:
3 hours ago, Stercorarius said:I believe the old flashlight is your best bet. IIRC Someone on here used one for a clay pigeon thrower.
Yeah, that’s what gave me the idea. I think I actually want the Fuel Hackzall, I might be able to shove the pump in the body if I cut out the bracing. Anyone know if a bilge pump can pump fuel safely? I’d like that as an option, another reason why I don’t really want the Milwaukee one.
wildroamer wrote:
1 hour ago, wildroamer said:What do you want? With my luck, any tool I buy won’t be working…:rolleyes:
Hey, bad luck is a kind of luck so you’re still lucky!
