thickness planer or combo
jon burgessMember since Mar 2015
i have a small shop. i want a thickness planer relatively cheap.(300-600) what is a good one to buy? or should i buy a jointer/planer combo.
Dewalt planer
tugnut1Member since Jan 2016
I think the dewalt DW735 is by far the best thickness planer under $700.
LarrySMember since Dec 2014
I agree with the Dewalt DW735. It is  a good planer to have.
Just make sure to keep the table waxed so the wood will feed to plane it.
Surfer (aka Nalu)Member since Jan 2016
jon burgess wrote:
I would not get a combo. Yes, they save on space, and you can pick up a Jet combo within your budget. But, the jointer/planer combo sucks at doing both things. I highly suggest picking up two separate tools. You will thank yourself in the end and be a much happier woodworker. I only have anecdotal experience with the combos, apparently, you will be constantly checking the blades for parallel when you switch between functions. As the crew members mentioned, the DeWalt planer is kickass. Have a look at the Rigid planer as well, I know the guys over at FineWoodWorking have given it a good review and it’s a bit cheaper. I have an old Delta jointer that works well. Jointers can be expensive, try Craigslist for a good old one.
hemdaleMember since Sep 2015
I’d go fro the Makita 2012 NB
prasetioMember since Jun 2016
dewalt dw735 sound so good
